Joule Thief
timmy1729
Quote from: gadgetmall on January 25, 2009, 12:56:25 AM
@jeanna . no i sad(yea right ) said it was something i found . Mine Is smaller . as soon as i can get me a SMT led  ill show it . the transistor and diode and coil are smaller than an American ant .. use to work on surface mount repair for Us cellular so its microscope soldering with pins holding the parts ..
@ IST your NUTS !!!  :D good video but i just don't know ..
@pirate  . thank for the comments . but you don't believe that My machine is Ou huh ?what is the definition of Ou . I thought it was for instance . take a battery resting voltage . It drops and rest at a given voltage then hook up something that takes power to run . My fanbedini  . Voltage goes down as expected BUT feedback and output voltage to the source and it goes up to resting voltage (unity) then goes even higher that resting voltage (over unity ) am i wrong ?
@ all thank you for being My Buds even though your all are  just  electrons aligning  numbers  0 and 1 in my processor on a flat screen monitor  :) you all are good Electrons some positive some neutrons and some protons . anyways you are fun to be with ..
I guess I'm the positron  ;D
xee2
@ Artic_Knight
Quote from: Artic_Knight on January 25, 2009, 04:52:45 PM
on a side note, adding a cap in parallel with the diod does not work it infact turns the diod off... hmm
You have to wait for the capacitor to charge up before the LED will go on. You may be using a large cap which takes longer to charge up. If you use a few pF it should charge up quick. The frequency is usually between 10 KHz and 50 KHz. I posted the frequencies for the camera circuits I built earlier. I am still waiting for someone to light a fluorescent tube from AA battery using self made transformer. I know it is possible since the camera circuits do it. Maybe you will be the first to do this.
Mk1
@xee2
Good idea! Give me a week , but anyone game on !
Edit: Ok it takes 20 mili at 1.5 v to make the jt work, I got 67 volt out even if its only 20 milli , 67v at 20 milli drop it back down to 1.5 how many amps you get?
Artic_Knight
well heres the facts even if ya dont want em MUAHAHAHA
the transistor unless you got a super special one is capable of 50,000 cycles per second, magnetism? well that has a limit based on the materials this limit has a name.. what was it.. hysterisis. then of course you have to account for eddy currents (or do you? maybe they help?) then ofcourse there is something to frequencies but i dont think any of us may be qualified to go down that road! resistances and another question is effeciencies... honestly whats the point, lets just take 15 milli and use it to power a friggen florecent to max power! then we can run our houses from (modded) florecent or halogen lights and even use the JT to tweek our heating systems, with solar hot water systems you can make yourself that work really well all you need is a good storage medium solar hot water makes for a warm house and the ground tap water makes for a cold one, combine this with a JT hacked 6v dc motor and we should have a cheep to operate water pump now take all of this stick it in a salad shaker bowl mix in a 20 watt solar panel and a 12 volt high capacity car battery or even cap bank and what do we have? all the free lights and heating/ac we need for our life powered by a tiny solar panel!  now if only we could extend a laptop runtime with this JT without Fudging the data and curcuits that would be fantastic.
well i got some time to spare so lets tweak.
Mk1
If we want a better world , we all need to stand together! And stop waiting for salvation!
