Joule Thief
0 Members and 234 Guests are viewing this topic.
timmy1729
Quote from: mdmiller on January 25, 2009, 06:19:02 PM
Mark can you enlighten us a bit as to what this might be about ?  Should I stay in bed ?  lock the doors? watch CNN ?
I second this question!
I've got over two weeks of sick time that I would LOVE an excuse to use some of!  ;D
innovation_station
to have a well tuned coil...
we need a digial scale
yep i got 1
i think to have a properly tuned unit  many things are at play .......but i bet mass will do it
equal mass or close but 1 needs be high self inductance and the other low self inductance
so lets look at it this way ..  and i bet this is incorrect  right now but it is my current view
3 9   =   low and high    6 med = output or secondaries
what will happin is this the low self inductance wind gets gets the power it then connects to the high self inductance wire wich closes the curcuit   for it to work like this you need a means to stop the flow in the low self inductance winding many times  and  i mean DONOT LET IT BACK FEED it must be A 1 WAY DEAL then when you cut the flow it can only travel out the secondaries.... the kick.....  a tiny amount is returned to the source from the high self idnuctance winding  hence its consumption is tiny ...  and its out is huge ..
so when the feild colapses it wants to go out the low self inductance wind ....  but  WE DO NOT ALLOW IT TO ...  and we know it wont go through the choke coil ... so it is locked in the toroide ...... in magnetic FORM ....
next it will look for the next path of least resistance ...
oh it just found it in your secondaries...  as long as the resistance is less than the choke and more than the low self inductance ..  and we block the return path to source
HEY ITS GOTTO GO SOME WHERE .... :)
ist!
this is my hemf tranny ... ;D
Mk1
@mdmiller
I will be watching cnn for sure but, i wish i could tell more,Harper will need a miracle to stay in place(a diversion at lest), the way things are going ufo may even be a possibility , on a concrete base there will be an eclipse. A world government is there end game , but could one bring every one together fear! I may take a weeks before we understand .The web bots are sounding the alarm.
timmy1729
http://amasci.com/tesla/tmistk.html
Check out this page! I don't know if it applies to the pickup coils we are experimenting with, but it might give some of you more experienced people an idea.
sparks
   @Inno
      Looks like a sm version.
   I just posted this over in Thane Perpectua thread which has digressed into uselessness as there profit makes it's inroads.
  It is a way to connect two torroids.
     A shorted highimpedance coil current will happen at a different time than the exciting magnetic saturation change.  This phenomenon can be exploited on a solid state level also.  Input spike on input winding saturates the core while inducing a voltage in a shorted highself induction coil.  The current in this coil is delayed not  effecting the impedance of the core to the exciter signal.  Then current flows in the shorted coil and is inductively coupled to the load windings.  You could use two torroidal high frequency transformers for this.  Pulse the primary on one.  Feed the high voltage secondary to the primary of the second torroid.  Feed the load from the secondary of number 2  torroid.    Make sure to use a resonant lc setup to feed the pulses into the primary or exciter torroid.   An active element like an avalanche diode in series with the exciter torroid output winding  and the output torroid primary will  help the tendency of the circuit to drift as the core magnetic parameters change.  Active tuning of the oscillator always helps but the circuit should run with gain.  The output of the secondary will be highvoltage high frequency.
     Inno's signature teaches us how to change highfrequency highvoltage pulses into a resonant low frequency high current  circuit.  When the inductor in this resonant circuit is a loaded motor you can do all sorts of things with the mechanical output.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
