Joule Thief
0 Members and 130 Guests are viewing this topic.
xee2
@ Mk1
I would guess that if you double the JT turns (from 4 to 8) you will get more voltage out of the secondary coil.
jeanna
Quote from: Mk1 on January 26, 2009, 04:10:43 PM
@All
All ,the last experiment , i made a 4 turn bifilar jt , the pickup coil is 112 turn 30 wire , with a 1k resistor it gives me 22 volts , and on a 1 ohm 100 volts.
MK1,
I am not at all sure about running these like this.
If the resistor to the base of the transistor is too low value, there will be more voltage at that base and more amperage from base to emitter and then it is in amplifier mode, not switching mode.
I think it is important to sort this out. The toroid will still be working its trick of making the light glow at lower than spec voltage, perhaps, but it may suck up too much juice while it is doing this.
I have seen lots of us doing this even the 220 ohm sounds too low to me, I really think this needs to be looked at.
thank you,
@ist,
Wow - 22 singles. I noticed your single turns are even less than what I was using. I will try this too.
Yes, my experience is also that this has polarity. only one way for those secondary wires on the led.
@xee,
Thank you for making that clear.
I guess it is 2 toroids in series, not 2 joule thiefs in series.
It makes a lot of sense. I need to go out for a bit. I will try it when I get back.
Thank you,
jeanna
innovation_station
@ sparks ...
this what you mean ?? 8)
ist
all copper is mass to mass tuned ...  they all weigh 1.8 g ea.
im a wind a supply jt for this unit and hook em all up
wonder what will happin ....  :)
jeanna
Quote from: innovation_station on January 26, 2009, 05:58:31 PM
purrrty = nice work, ist.
How many turns did you count for these?
jeanna
sparks
@Inno
     Thats what I mean.   But you series connect em.   A  pulse wave modulator will free you up to match the waveform to the input winding on the exciter torroid.  You want to pulse it just enough so that you choke the current and harvest the magnetic field response.  If your pulse duty cycle is too long you oversaturate the core and waste the input energy.  I haven't studied the jule thief enough to see the exact components needed to accomplish this.  But a pulse wave modulator becomes your vic or voltage input circuit.   Then short out the "high voltage" winding on the exciter torroid using a primary on the ouput torroid.  The trick is to get the torroid cores back to ground state before the next input pulse comes aboard.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
