Joule Thief
0 Members and 188 Guests are viewing this topic.
Pirate88179
@ All:
OK, once again I am showing my ignorance. (I am getting used to it)  When I posted about the Fuji circuit using 1,240 mA's, I based that on testing the battery I used by itself.  I figured it could not draw more mA's than the battery had in it, which is probably true.  Now, if I wanted to test on how many mA's it is drawing while lighting 400 leds....how would I do this exactly?  If it was using less mA's than the battery had to offer, then my numbers of mA's per led would drop way down I would guess.  I really have no idea how to measure the current draw when connected to all of my leds.  If someone tells me, and I have the stuff I need to do it, I will do it.  I just figured that with the heavy load of all those leds, it would be using everything the battery had to offer.  Once again, I may be wrong.  Thank you all.
gadgetmall
er Bill you put an amp meter in series with the battery . the meter i used had 2000ma 20ma and 200ua . My little Fugi power pack put the meter in OL on the 2000ma using a new Metal-Hydride 1.2 volt battery with 2400 MaH . Now i lowered the input current By putting a 680 pf cap across the base resistor to coil and got it down to 1900 and some and i think this can be got even lower with a variable resistor (pot) in series with the resistor by the transistor . Also i Might add that this is factory made and don't count in the Who can get the Lowest ma draw Contest  :) But this Fugi is VERY important .and you win the who can light the most LEDS with a 1.5 volt battery so far !! SOMEONE needs to wind a homemade fugi Toroid . I understand that was Mk1'slittle Contest .Who can Light a tube up First with a homemade coil . When that happens then i think Further improvements can and will be made to reduce the input current to light 1000's of leds for less than 1 ma total . Just a guess but because this is "cold Electricity and you can light up a string of 100 with one wire then it make ggod sence that this is Different electricity than a regular Jt . Its something More .
innovation_station
my sg coil is almost done   NO!! that does not stand for school girl ....  lol
i only used 6 coils ... but it is verry kool :P
ist!
Cap-Z-ro
Better reread that GM...you will see that my mule is named Friday...same as your horse.
And I think my mule may have been around longer than your horsey. :)
Regards...
Freezer
