Joule Thief
0 Members and 89 Guests are viewing this topic.
Mk1
@all
More info i found .on mag amp , http://www.butlerwinding.com/elelectronic-transformer/mag-amp.html
                                              http://en.wikipedia.org/wiki/Magnetic_amplifier
There is a book from 1951
"Magnetic Amplifiers by the U.S. Navy (1951), edited by Trinkaus. First came the vacuum tube, then the transistor, right?. Not really. In between there is another lost entity. Electronics engineers of the 1950's believed the rugged little magnetic amplifier was going to replace the fragile vacuum tube in all its functions under a megacycle. Originating in the USA but adopted and developed by the Nazis for the V2 missile, the mag amp after WWII found a clique of boosters among US electronics engineers. This document, unusually passionate and well written for a military tech manual, is their promotional brochure. Evident today only in some motor-control and power-supply regulator applications, the mag amp not only can regulate but can magnify, modulate, switch, pulse-generate, invert, convert, multivibrate, phase shift, and multiply. Mag amps require zero maintenance, can be made indestructible and EMP-proof, and can handle up to 200,000 amperes. Modulate your Tesla coil with a mag amp. This booklet has been completely reset and redesigned for economy and readability. 43 illustrations."
from http://www.teslapress.com/catalog.html
@gadgetmall
It still new to me i will need to build it first to be of more help.
Thank everyone !
jeanna
Cool,
Now, the circle comes back to the beginning. George Trinkaus wrote the 2 booiks about Tesla (the coil, and other inventions) which so inspired me that I began to search for an understanding and a way to follow up on his work to give it freely to all... which has led me here.
I love it when this happens.
@Koen,
Welcome. This is a fun sandbox. It seems to get bigger every time someone else joins! So, com'on in and join the fun.
I would suggest (since you asked) that you get a torus (toroid) made of ferrite, and wind a simple joule thief. It is the basis for all that we are doing, so, you might as well have one or 2 or 3 of them lying around. Check out evilmadscientist.com for the instructions. Or did someone already post them? I or someone can get the good instructions to you if you cannot find them.
Once you have it set up - and using a breadboard might be a good idea, since we change things around a lot- take out the led and wind a secondary and light a few leds from just the secondary.
You will be filled with ideas and you will know where you want to go from there.
Again,
Welcome,
jeanna
nievesoliveras
@gadgetmall
Thanks You!
I will check if I can understand it and let you know.
Quote from: TheNOP on February 02, 2009, 04:49:11 PM
nievesoliver
try force your motor to turn backward
you might have a supprising effect.
I think that the only thing that needs to be done in order to force it to turn backward is to spin it backward initially. I may be wrong though.
Jesus
nievesoliveras
@gadgetmall
Pardon my ignorance. But there is still not continuity connection between the toroid coil and the transistor.
Jesus
gadgetmall
Quote from: xee2 on February 02, 2009, 04:38:48 PM
More test results. It looks like with a 5K base resistor the circuit should be able to light up 20 to 40 LEDs in series while using only 4 mA of current from battery. The LEDs would be put in place of the voltmeter.
Hi . That is Why i put a Vr in there with a small Value resistor to protect the base . I adjust it because Each color or model of LED takes Different Voltage . What works for My led Might not work for others .. Needs a Continues  Bias adj  in my opinion  :) But thats because i do a lot of testing to . once a value is attained i guess a solid one could be put in its place .  Question . If i have a 680 pf across a variable resistor and use only wiper and one end  will it adjust the capacitance too ? I have lots of Darlington's from the old power supplies . They Hook up the same Correct . I all ways used two xsistors .  .
