Joule Thief
innovation_station
@mk1!!   im on it bro  8)  4 turn jt  and bifillar pic up coil ...
jim ..   wow
how in the heck do i build what you describe ..... ;D   i think i have all the parts but the bc.... transistors ...   but i will look round see if i cant round up enough parts ..
GRUNT ...   ;D   I CANT WAITE ... LOL
ist
timmy1729
Quote from: gadgetmall on January 31, 2009, 02:16:07 PM
Hi as a matter of fact i have heard of antennas pulling energy out of the vacuum  of space ! Thats Exactly how to make what they call and earth/air High Voltage Battery . You ground a copper rod in the earth and attach the wire to one end of a Hv cap then run another wire 200 feet up . and attach the other end of the HV cap . You will have a limitless  supply of high voltage only limited by you cap Voltage . It will light neons and probably CFs and florescent tubes .  i got two of everything from High powered burning lasers to tesla Flyback . down to metal that catches on fire when it gets wet and metal that is solid at room temperature and turns liquid at 108 degrees.Radioactive rocks and yea tons of ham radios  and junk i have collected from the past ..Im a Pack Rat . Here is one of my latest Toys . i need a tube for it . one was broke . 6CW5  This baby put out pulses from .01 kc to over 2.5 mc at voltages at adj. voltages up to 40 Volts . Now i wonder what a TPU or a Toroid / Coil will do with that !!  :o I'm gonna find out !
It just so happens that I've got three copper pipes in the ground as part of my earth battery setup. I guess I could hook those in parallel, attach one end of the cap to the last pipe, connect wire to the other end of the cap and run it. Would one of my 320v caps from the camera stuff work for this? Oh, so to light something like some LED's, how do I hook them into this?
jeanna
Quote from: electricme on February 12, 2009, 12:54:49 AM
May I call on your help Jeanna with my TWV,
OK here tis
jeanna
Quote from: Mk1 on February 12, 2009, 05:02:12 AM
Now i know what i needed , it doesn't need much on the jt side , so more space for pickup coils . It will have 4 coil, 2 bifillar if you will.
Edit  if i go back down i get 40 turns and 105 volts.enough to light my neon.
I look forward to seeing you results with this , Mark.
This is the direction I was trying to go and I got flaky and disappointing results. I am glad to see you doing this using your methods and toroids.
thank you very much,
jeanna
jeanna
Quote from: Pirate88179 on February 12, 2009, 01:06:25 PM
http://www.youtube.com/watch?v=GVLs5BywOVE&feature=rec-HM-fresh+div
Have a look at the above video.  This fellow is using a joule thief circuit to make hho.  I think Jeanna would be interested in this.
YUP,
and right below it:
http://www.youtube.com/watch?v=Ru8YQ6HUwbU
So, gadgetmall, we may not need to do a whole thread for this in the spring afterall!
Yeay! everyone is jumping into the pool!
jeanna
