Joule Thief
Mk1
innovation_station
nice dwg
thank you for your time to do this ..  i have also 1 green 1 "
i will now build it ..
ist
nievesoliveras
@mk1
Thank you for the diagram!
The only question I have is the direction of winding of each individual coil.
Can you add an arrow pointing the direction it most be winded?
Thank you.
Jesus
Mk1
@jesus
This circuit is tuned for my toroid, meaning i have found it sweet spot just enough turns on the jt side 4 each, 3 and 5 lowers the voltage, when i perform the test i always re adjust the base resistor and check with the best resistor value for the jt coils that way i don't get confused by the bat voltage or different coil resistance, i tune it to its max , then get readings.
It gives me 4 times 76 volts dc  or 2 times 140 volts dc. improvement can be easily done since i still use the 2n3904 and original circuit.
A different toroid will need test and adjustment to perform has well.
Mark
I bigger toroid can be used, test the jt coil first to get optimum results , then put as many turn on the pickup coil as you can.
60 inch is for a 1 inch toroid. And 22 mag wire , otherwise it won't fit.
innovation_station
here is a pic of mk2 green toroide
my first crack at it ...  i did it wrong....  the windings are correct but i left toooo much wire at the start of the coil as when i came back down i only made 7 turns not 10 for a total of 19
so i will REWIND IT ... BE SURE TO KEEP IT TIDY AND RIGHT ON OR 60 "   WILL NOT WORK OUT IN TURNS ...   8)
HERE IS THE PIC
IM GONNA DO STEP BY STEP PICS   after i fit it in properly ...  8)
ist
