Joule Thief
0 Members and 25 Guests are viewing this topic.
Mk1
@ist
I was trying a 2 transistor like the one Jesus found, it work but can't get more then 35 volts a coil , so if i can't do better then that then, its worthless, it worked right away but i still need to find the right value for resistor. So fer the regular jt circuit, is so much better an simple.
I am checking different transistor , but we need a easy to find one. I will try 2n3055. i will be back.
Mark
nievesoliveras
Quote from: electricme on February 14, 2009, 08:43:43 AM
@Jesus,
Hi there friend, I havent pulled apart one of those mobile chargers yet, so they have a torid in them, thats interresting.
Hope you have success with it.
Im looking forward to hearing how you go with it.
I gotta hit the sack
Hooroo
General Jim
Maybe I did not explain it properly. What I used was the coiled cable from the phone charger.
I wounded it over the toroid I had and made a multivibrator. The output was dissapointing, just 0.12v rectfied.
@innovation
I will consider your toroid sale offer.
Quote from: Mk1 on February 14, 2009, 05:31:53 PM
@ist
Mark
I was telling @general Jim that I built the multivibrator also and the output rectified was 0.12v .  If I tested without rectification, the meter wont show anything, 0, nada.
If @ist gets the whole thing going maybe it is better to get money to buy one already made from him, then use it to learn the principles involved and as a light source as well.
Jesus
Mk1
@nievesoliveras
i have built the 12volt to 230ac , for telia, and not really impress, i can't tune it well, and takes twice the the parts.
Remember if you don't put a rectifier on it , your meter it will show nothing, have you connected a led on it for fun?
Mark
I don't think your phone wire helps.
nievesoliveras
@all
Up to this moment we have this:
Any suggestions for the circuit to use?
Jesus
nievesoliveras
Quote from: Mk1 on February 14, 2009, 06:12:37 PM
@nievesoliveras
Mark
I connected a red led that its the easiest one to light and it did not light, then when I rectified it and measured it, it gave 0.12v dc output only.
I will try to use the primary as secondary and the secondary as primary and test again.
Jesus
