Joule Thief
0 Members and 135 Guests are viewing this topic.
electricme
@ jesus,
Try   http://www.sofotex.com/3GP-Player-download_L45547.html
address to download a free video player that can play those 3gp video files
I havent tried this one.
I just googled 3gp video player and this one popped up on the screen.
Hope it works ok.
General Jim
gadgetmall
Hello Guys and Gals(Jeanna)  :)
       well Here is a Partly Modded Fugi AAA circuit lighting a cfl . I have not ran a time run on it it nor checked the current just yet  but did manage to light a 45 watt cfl good and bright .The Mod to do this is not hard at all .
@ General Jim .
       My Good Friend Down Under .iI want to Thank you so Very Much For Helping Me out even when i didn't even ask you too. You are a True Hero In My Book and Have One Big Heart on ya there Mate . I have Something for You too .  ;)  I think you will like it .Keep up the Great Work as i have been Slacking a bit cause My Daughter is sick now for 7 days and am exausted but lord willing i'll keep the ticker going  :) LUIC
@ Maw2432
             You almost set . Many thanks and you also have a Big heart . One Great Teacher !!!  ;)
@Pirate
        Thank you Very Much . i will be Contacting you and let you know what the happs are  :o . Its good !  ;)
And your set too !!  ;D
gadgetmall
Quote from: nievesoliveras on February 26, 2009, 07:29:09 AM
Maybe you are doing something great on all your small videos. But saddly I have not been able to see any one of them. My machine does not see that kind of videos. The ones that end with .3gp.
Do you know of any small free viewer?
@pirate
How you doing?
Jesus
Download Quicktime
gadgetmall
Quote from: Pirate88179 on February 24, 2009, 08:56:26 PM
@ MK1:
About two weeks ago, I got the program malwarebytes as suggested by Gadgetmall and, even though I am using spybot, adaware and AVG and firefox, Malwarebytes found 6 items hiding in my computer and these were all high risk items.  I have had no problems since.  Just thought I would give a testimonial for it.
Yes it is the BEST Antispyware remove on the net and highly recommended . It finds stuff spybot and microsoft antispyware and Xsoft and All of the so called spyware removers(BULL) . and Of course it is 100% free . It will fix your problems is its bug related and your hijacked . Recommended by all the hackers !!.
electricme
@all
I also decided to make a dual JT running on one 1.2v Nicad cell.
Got stuck into those two green torids, put 20 bifilar turns on each one.
They are not running in parallel, as they have seperate feeds to seperate transistors.
To bring them into sync, I will solder a wire from each transistor base to base, I should need just the one 1K resistor
They work nice.
Tomorrow I will begin the 480 turns secondary on each torid, gonna have sore pinkies!!!!!!!!!
@jadaro2600
Was it you who was having weird motor running on your joul thief?
Anyway, I remember way back, I could run a 12v PC fan for a couple of seconds, then it would run down and stop.
I discovered it was the CAP, it took a while to charge up, but the JT wasn't putting out enough current to overcome the current drain of the motor. I have been waiting for more identical size torids to wind and connect them in parallel to see if I could get milliamps that way.
Thats one reason I bought that rotary LED kitt, so I can alter the (mark-space ratio) time allicoated to charge up a smaller cap, then when the last LED lights, discharge all 8 caps into the battery.
How I think this should work.
The 4017 IC  has 10 outputs, if I take the 1st to the 8th to control the (eight seperate capacitors) charge, the 9th will put a "hi" on 8 seperate diodes to the bases of 8 bc548 transistors, which will dump the voltage accumilated during each cycle and dump it back into the battery driving the whole shing bang. The 10th output will go back to the reset pin on the 4017 IC, it will go through the sequence automaticly all over again.
The 555 timer IC is to control the speed of the 4017 IC chip.
In theory it will work, only thing is, the 555 needs at least 4.5v to work, same with the 4017 IC.
I might have to kick start it with a 12v battery, lol
General Jim
