Joule Thief
0 Members and 51 Guests are viewing this topic.
Mk1
Quote from: altrez on March 13, 2009, 01:57:47 PM
@Mk1
Thank you for spending so much time to help me figure this out. I have a 1 k resistor and the npn3904 transistor. The wire for the bifilar coil is from a CAT5 ethernet cable. The toroid is from radio shack.
Thanks!
Ok , your wire is multi tread , or single , single work best and is easy to twist around the toroid, that will look better and work also , and there will be more space on the toroid, those toroid may need more turn to be effective , so lets go all the way around first , make it work with the jt light , really make sure your transistor is connected properly , because the connector and emmiteur are reversible
but really work both ways but are not working as good.
When done test again with a pickup coil over the other coils
That should get you started , you need to learn about your toroid , and how many turns needed.
Mark
altrez
@Mk1
Ok here is my plan of attack for this evening. I am going to rewind the toroid all the way around. I am then going to test it with my LED strip. If all looks good at that point I will wrap a pickup coil around the toroid and post what happens.
Thank you!
ScienceMan
@all
I'm in the middle of winding a coil but I'v got something to ask...
What are the black dots by the coil symbol in some circuit diagrams? ???
And also, does it matter in which direction I wind the coils?
Thanks
SciMan
Mk1
@ScienceMan
It indicates coil direction , you can worry about it later when its time to connect everything to the transistor .
Mark
nievesoliveras
@all
I just finished reading about 20 pages now!!!
Quote from: ScienceMan on March 13, 2009, 03:21:21 PM
@all
Thanks
SciMan
The black dots on a coil representation mean that those ends are winded on the same side. Almost always those dots are situated on the two end wires of the bifilar coil in this case.
Jesus
