Joule Thief
0 Members and 115 Guests are viewing this topic.
TheNOP
Quote from: slayer007 on March 17, 2009, 04:53:32 PM
I was woundering if done with a toroid if the magnetic force would keep going around the toriod.
Then if you had a couple pickup coils in bettween the two main coils if you could pick up any power.
the answere is..., no.
no mag field change, no voltage on the secondary.
Mk1
@slayer007
so you are talking about the perpetual motion holder , it is made from a u shape magnet, and are responsible for rotating the magnet wheel. If you put a iron bar on it it closes the magnetic gate so that the current travels trough the magnet,it also store energy , released when the magnet is pulsed. i will try to find my old info on it , and post it.
Mark
slayer007
Quote from: Mk1 on March 17, 2009, 05:08:07 PM
@slayer007
Mark
Yes, MK1 thats what I was talking about.
TheNop just posted it wouldnt work I was hoping the force would bounce back and forth between the iron plate from coil to coil.
But I dont know it was just a thought
Mk1
@slayer
there is something similar to that holder on a coil , is called a hall sensor or generator.
Mark
But keep you idea coming please.
rensseak
Quote from: jeanna on March 17, 2009, 04:27:44 PM
I just made a totally copper thingy. It is made the way the guy on the youtube video linked by jadaro showed.
1" diameter 5 turns bifilar wire around that then continuing with 10 turns around this core. It lit the primary jt led.
It lit it well,
but I did not get anything from 5 turns of a secondary.
If someone else gets good results with this I will try some other numbers of turns etc.
I spose it is an OK way to make a standard joule thief, but it won't be doing what we are doing.
I just reviewed a bunch of my others. Yes they are still good.  ;) They didn't weaken from neglect.
On to a MK2 or 3!
jeanna
Hi jeanna,
i did it also except that i have about 25 to 30 turns around the core. that is really surprising for me. and look how many LED's. i will let it so till tomorrow morning. i used the wire from a LAN cable.
Norbert
