Joule Thief
0 Members and 55 Guests are viewing this topic.
TheNOP
@jeanna
amplitude is the difference between the lowest value and the highest value of what you are measuring.
amperes is a measure of the amount of electric charge passing a point per unit time.
ex: 1 A = 1 coulomb / 1 second.
the peek value of a signal wave/pulse alone is not enough to tell you the energy quantity you have.
you can think of the voltage as the pressure in a hose and the current as water flow.
in the jt transfo case, the spikes come from the pressure.
ex: you would not want to put your hand in front of a 3600 PSI pressure washer.
suprisingly, the quantity of water(current) flowing out is not that big.
but look the work those machine can do at that pressure.
W = I * V
I  is the current
V is the voltage
W is the power in watt
jeanna
@mk1,
I never used any diode in the joule thief except when I used the bridge for checking the output voltage.
Is this what you mean?
or do you use a diode to keep things going in DC?
(I can't imagine why you would switch to dc after achieving ac, but I don't understand some of these points at all.)
thank you,
jeanna
innovation_station
the reason i switch it to dc...   is because the AC FREQ  is tooooooo HIGH ...
rectify  it and dump in a cap bleed off cap to charge batteries ....  or  WHATEVER U WANT .... ;)
this solves the high freq ac thing ....  to a point ...
if we used iron...  i bet we can get 60 hz ac out of it  ;) lol
almost done the MK HV!   quite a few turns to it ...
ist
TheNOP
Quote from: jeanna on March 18, 2009, 12:15:05 AM
jeanna
yes
the voltage you can get can go higher then the reverse voltage limit of the diode you might use.
if thisoccure they will blow up.
Mk1
@jeanna
The diode are mostly needed for running other electronics most work on dc, but in the case of led it doesn't really mater ,
i also use them to check voltage and comparing to ac , it give ma a idea of the wave form , since i don't have a scope.
I guess so far i am just finding ways to get juice out , but not finding uses for it.
So what are your goals .
Mark
