Joule Thief
0 Members and 82 Guests are viewing this topic.
Pirate88179
Mine were in parallel now that I think about it, for whatever that is worth.
Pirate88179
@ Jeanna:
On this page are some close-up photos of my board.  You can compare to what you have.  Let me know.
http://www.overunity.com/index.php?topic=6123.290
One difference is that since that was taken, I cut the lead to the diode on the end without the stripe as was suggested to me.  That really helped my output.
jeanna
Thanks Bill,
That will save me hours!!
jeanna
jeanna
I think the fuji I bought is closest to zee's, but I still think it is different. I have been to joseph pino's site and removed much of what should go, but I have a couple extra resistors and I have a black/grey thing that I believe is a diode as well as a glass diode.
The glass diode has a yellow stripe. Is that the (-) ?
So,
2 diodes,
3 resistors,
1 darlington transistor,
1silver thing someone said was a TDK cap,
1 large transformer,
1 coil,
battery holder still in place as copper braces.
I am not sure which resistors to remove. There is a black paint over the lines underneath so I cannot read where they attach. I can read one of them which goes from a switch to the silver cap.
What was that thin black plastic thing with 2 copper leads. It seemed to be in the right place on the camera to be a switch or a cap turn on somehow... Anyway, it is gone.
xee did you end up with a bulb glowing from your fuji ckt?
I think I am close. I better study the circuit some more to understand what it is supposed to be doing.
jeanna
Pirate88179
@ Jeanna:
That thing with the copper contacts is a contact switch.  You remove it.  I only have 2 resistors, that funky metal cap and the transformer and trigger coil left on my board. Everything else is gone...well I left the diode because you hook a lead to the side with the gray stripe on it.  (not sure if anode or cathode)  I just cut the other side and bent the diode up from the board a bit.
