Joule Thief
0 Members and 158 Guests are viewing this topic.
Pirate88179
Mark:
Nice drawing and pic!  Does the clipper coil have a core?  Looks like a lot of windings there.  So, I just use it as a pick-up coil then?  What do you think it will put out as far as volts/mA's?  I have had my eye out for an old set of clippers ever since you raised the idea way back.  I hate to salvage the parts from mine as I cut my own hair (what is left of it) and have for over 30 years or so.
Maybe I can find some at a second hand shop...I will check around.  Heck, I can buy a new pair for about $20.00 which is probably cheaper than all that wire would cost me at Radio Shack.
Great post, thanks.  I need more power....I always need and want more power.
Mk1
@pirate
I got 3 of them my self on my bedini it reaches 120 v ac, on a 12v dc supply , there is over 1000 foot of wire and there is a core usually easy to remove (if you like air core, really doesn't work that good ) The core is good for high voltage .
My bedini if you remember the picture , is a bedini fan first , the fan circuit charge battery and give rotation , so the dick on top is free and doesn't need pulsing , the disc is made of hard drive disc with 5 hd magnet so the disk is N-S-N-S-N-S-N-S-N-S, 5 cycles per rotation , also the disc design permits coil over and under it.
Mark
nievesoliveras
Quote from: Mk1 on April 06, 2009, 02:31:43 PM
The letters are the 4 pickup coil needed to make this, where it say ac its only referring to the diode bridge .
Also i made a mistake in my explanation or the drawing , i know it works i used the drawing to test and got good results
But did i make it like i said instead ?(by mistake)
But if you want to have power to charge cap fast , you don't need that , you just need cross wind pickup coils , use 30 gauge and make it into one wire by twisting them together all of them will fill caps fast.
Thank you @mk1 !
Jesus
jadaro2600
Quote from: Pirate88179 on April 06, 2009, 03:16:43 PM
Mark:
Most newer models contain a motor, and not a large winding...  the motor has an offset axis, so that it can cause the teeth of the electric razor to vibrate back and forth wile attached to the axis.
Mk1
@jadaro
Hair clipper not trimmer or nose air remover , lol, i have coils for 3 different maker , even those from wallmart.
