Joule Thief
0 Members and 50 Guests are viewing this topic.
jadaro2600
Well, considering this, has anyone tried to attach an actual signal generator to the coil to establish what frequency, if any might be more beneficial than another?
Someone had a diagram of a 555 powering the the whole affair, I was thinking that this may be an easy way to optimize a coil setup, then move to a circuit without the timer having been familiarized with the operating environment under different frequencies.
The core itself is given to chance from person to person, perhaps an optimization method may be in order.
There is tuning with resistance, as has been mentioned before.  Has anyone tuned with a fixed current and a variable frequency, or variable capacitances involved in the blocking oscillation action?
On another note, I though about the voltage slamming effect - I refered to it as such because the voltage is produced when the transistor turns off and has no where to go but through a load..
I built a PNP type jtc, and put all of the coils on the opposite side of the transistor - in such that, any large voltages will already be at ground..I may be mistaken though, I'll have to go back through the diagrams.
..and here one is.
altrez
It is my understanding that you do not get extra current in the pickup coils? For example If you have 3 amps going into the pickup coils it will be shared between the 3 coils that would give you 1 amp on each coil. Not 3 amps on each pickup coil. If that was the case we would have over unity would we not?
I might be completely wrong :) And if so can someone please be so kind as to explain??
Thanks!
xee2
Quote from: altrez on April 08, 2009, 06:18:44 PM
That is correct. If the coils are identical, the current will divide equally.
EDIT: The loads on the coils need to be identical also for the current to divide equally.
Mk1
Thanks!
Lets not get into this again , but make one , then tell me !
innovation_station
maybe this is where resonance fits .. :P
lol
ist!
TYG4U ......MK1!!
