Joule Thief
0 Members and 64 Guests are viewing this topic.
jeanna
Well cap,
your wish, said the Genie...
This is what I posted which had to do with the "download". I actually saw 3 coils on 3 axes, but couldn't figure how to do it without them getting in each other's way. Sterling did it.
Here is the pic. I took the pretty part off the Nassim Haramein website TheResonanceProject.org because to me they relate in an important way.
jeanna (aka Genie ;) )
TheNOP
Quote from: Cap-Z-ro on April 15, 2009, 05:25:34 PM
It may be worthwhile to wind a j/t in KLM fashion or to incorporate one or two into the j/t circuit.
These KLM coils are really cutting edge thinking.
sorry, but for having tryed something similar and what the guy actualy say of it experiment.
Quote"1st example power station runs for many hours depending on load and charges it self. The only problem i need to over come is a 00.01 point loss over time then it holds at 12.15 and slowly go's 00.01 lower and get's slower losing charge and takes at least 20 minutes now to lose 1 volt by itself because the charger is sucking to much power then it's putting back into the battery. All i need to do is make the 00.01 climb and i'm set to put any load on it :) that it can handle :) The TV was allot of watts for the system to handle it's self in 6-7 hours just lost about 2.3 volts the safety features of the inverter shuts down the system if voltage drops to 10.5-11"
he could have achive 30 minutes to an hour more without the charger.
those coils don't do much the way he use them.
might worte trying with a jt to see what would be the output tho.
but i don't expect much out of it.
it is not much different then an ordinary inductance with a bit of self inductance added.
@Pirate88179
congrat for your new "baby"   :)
Cap-Z-ro
Thanks Jeanna...was that memory, luck, or esp ?
I will have to let that thing simmer a bit in my mind.
@NOP...I am more interested in the antenna aspect of that concept, in relation to Pomerlou's circuit.
I see potential there, and in combination with j/t properties.
I have to ponder the possibilities a spell...there are so many variables involved here to consider.
If Jeanna is receiving "downloads" maybe she could be the one to put it all together...as most of the greats were good 'receivers'.
Regards...
TheNOP
@Cap-Z-ro
from what i have read about Pomerlou, the phemomena are closely related to him.
his device does not work without him being there.
i guess this rule most of us, if not all of us, out of OU with replications of his way of windding coils.
jeanna
@Bill,
I bought 2 kinds of paint today.
a garish yellow that glows greenish under a uv led. It says fluorescent paint.
The other one is glow-in-the-dark.
It does not say fluorescent. Nor does it need a uv light.
It gets charged with light then glows when the light is off.
It might be fun. Maybe I should strobe it, or something.
I got a strobe effect today on the 2tier set-up, with a battery dying at 1.09v when rested, but .54v when working. The supercap in the battery rail kept up a good strobe, if slow. It was quite even.
I think the former is what you have. So, count me in!
I painted the inside surface of a small glass tea-light candle holder. It needs a second coat.
I have a small question. How many uv lights are you using? It looks like 2- one on each end. Is that right? I think I will solder this one, because I am fresh out of breadboard space, and besides it might be a good job for a real joule thief with 2 uv leds on a secondariy
Do you have any advice?
I will post a picture, of course, when it looks like something.
Right now, the paint looks very smear-y because there is only one coat. I hope one more will do it.
This is fun.
Thanks for the idea.
jeanna
EDIT.
The reason I mentioned the 3 axis configuration back whenever  was because something jadaro was doing with multiple choke coils reminded me of it. He was using the joule thief concept but with a straight line configuration, so I offered it to him.
