Joule Thief
0 Members and 105 Guests are viewing this topic.
Mk1
@pirate
Lol, i hope jack will do !
As long as we can stay away from human butchers .
Mark
electricme
@all
I have just been listening to the Regional and the National Australian news on ABC TV.
They mentioned the Swine Flu which is in America, hold onto your hats, guys n gals, it has hit New Zealand, there are 10 recorded cases already there.
None here in Ausie so far, I expect this to change in a few days. :-\
Although I have a burning question, just how come this flu appears in America and New Zealand within the same day?
It usually takes a few days to incubate before symptons to show up, this smacks of delibratly being spread. >:(
I was speaking to Bill yesterday and we both didn't have any idea of this, and this is so widespread, I think it is a NWO thing.
If you want any chance of travelling through it better than others, then google for "MMS Jim Humble"   ;D
Then order a "starter kitt"
Or gointo a health shop and ask them about it.
Take vitamin C for at least 2 weeks before you begin the MMS
@Bill,
I will send you my "accent" hahhahahaha ;)
Pirate88179
G'day Jim:
Actually, I heard that this originated in Mexico.  Then quickly moved into southern California and several other areas of our southwest. (Close to the Mexican border)  The problem in modern day society is that if someone coughs on you in southern California today, and you get on a plane (exposing everyone on the plane as you breathe the same air) and go to NZ then infect 10 others there that infect 10 others....it will grow exponentially. (and I am not good at math)  All those other folks on the plane will also infect countless thousands.  This could get very bad very quickly.  I don't know what the incubation period for this is but if it is like a typical flu, 2-5 days.  So, there were already thousands probably infected or exposed before the first symptoms showed up in the 2nd wave of infected folks.
Be safe everyone.  Thanks for that information Jim.
hazens1
Quote from: jeanna on April 25, 2009, 10:43:04 PM
Hazens1,
I keep forgetting to ask you. On your 7T,7T,70,70
Is the 70,70 done like the MK1? Which means did you go up 35, down 35 then across and up 35 then down 35?
I have a 7T,7T,70 and I would like to make it into a replication.
Is it on a medium?
thanks
jeanna
Nope, It's all one direction. I wound 7t Base, then 7t Collector then 70t Pickup on the Goldmine Medium 5 for $1. I later came back and wound a second 70t Pickup in between the previous 70t Pickup. On the Pickup coils, the inside layer is a double and the outside layer is a single. This is all done using 26g magnet wire. If you think about how the 2 pickups are wired in my latest tests, it is actually a 7-7-140 coil. I plan on making this MK1 style when I have time to wind more coils to compare performance.
Mk1
@all
The incubation period is 10 days without symptoms , 10 to infect your friend and loved ones.
This is not a joke.
Mark
@hazen1
Can you test for dead spots, make a single turn pickup coil , and check the voltage around the toroid by moving that coil and checking the voltage with a bridge, depending on the toroid there may not be one, but you will see , so basically look for a spot where there is less voltage or none. This will tell you if the design could be improved.If there is no dead spot then use smaller gauge to make more turns, to improve on your design .
i hope this will help
