Joule Thief
0 Members and 96 Guests are viewing this topic.
TheNOP
Quote from: Mk1 on May 17, 2009, 05:35:42 PM
I personally only use the full wave bridge because it is the most efficient , it allow 2 time more current to come out then a single or double diode rectification .
you do.
but i remind you that your jt's coils and pickups are made in such a way that the transistor's base strenght is almost not affected when letting the current flow in either direction in your pickup coils.
what is benefic in a particular setup might not be in all setups.
xee2
@ gadgetmall
The base coil looks like it has two inductors on it. If so, do you have both in series or are you only using one of them?
Mk1
Quote from: TheNOP on May 17, 2009, 06:04:44 PM
you do.
@nop
Yes i made most of the steps on the coil design front but i see a future where some more steps will be needed going beyond cfl and leds.
gadgetmall
Quote from: xee2 on May 17, 2009, 06:07:56 PM
@ gadgetmall
are in series seperated and joined at the middle . ferrite rod slides .. here is the output circuit in cave man style
jeanna
OK gadget,
I was about to post to xee that there is one cap he has missed in his drawing. I was trying to redraw it for myself and I saw this, and I cannot finish until it is clarified either.
Now your hand drawn has only 2 caps in the output part also?? ??
Plus I can't follow what that means, "separated and joined in the middle".
I can't do that one at all!  :D
please help!
thanks,
jeanna
