Joule Thief
0 Members and 242 Guests are viewing this topic.
jeanna
Quote from: resonanceman on May 24, 2009, 08:13:32 PM
The  only problem  I have had is  the  JT  drifing  out of  resonance .   If it  goes out of resonance and the  battery draw  goes up   it starts draining  the  battery .
Hi Gary,
I really don't know that I was getting ou. I am not looking at that part of things.
The reason I suggested to use the same size jt for the second tier was this.
I think it is possible to get matches with others, but you know you have a chance at keeping the vibes at about the same frequency when you have the same toroid on the second tier.
Take a look at my 2 tier stuff and see if you don't see the same thing, well similar.
I didn't use a diode but I did because I used the light emitting kind.
I found 3 or maybe 4 distinct places where there was significant light and where the draw did not increase or the light diminish when I added more.
The loop of current was amazing.
See if I didn't get what you are seeing.
jeanna
altrez
@all
Well some more tests with my new pickup coil. I can light two strings of LED lights not all of them for some odd reason some on each string just will not light. Not sure why?
I am also using the basic JT circuit would it help to change out the transistor or resistor to get more performance? Right now thanks to jeanna :) I am seeing voltage spikes in the 340v range!
So my question is should I unwind that new pickup coil and rewind a one with 30awg wire at 300+ turns? Or try and work on the back end first? I am sure that I can push over 1000v with a 300 turn coil.
Thank you!
-Altrez
WilbyInebriated
nice job!
is it every other led that doesn't light?
altrez
Quote from: WilbyInebriated on May 24, 2009, 11:44:29 PM
nice job!
Thank you! No its just random ones from each string. I tested them and they all work when plugged into the mains.
-Altrez
jeanna
Quote from: altrez on May 24, 2009, 11:37:03 PM
@all
Thank you!
-Altrez
I took my string o leds apart after I got them to light and only half of them lit.
There was a diode in the first and the middle or other end light. I think It probably protects the string from surges which would kill it under normal wiring conditions.
There were 3 wires at each of these fatter bases. The rest had 2 wires and were smaller.
340v
cool.
Are you using a breadboard? If so it is an easy job to try a few different items.
In fact.
Put a pot -I used a 1k pot for this. And with the scope on the 2 secondary leads, slowly turn the pot and watch what happens.
This is where I first noticed that as the frequency goes one way the voltage goes the other.
check it out.
jeanna
