Joule Thief
0 Members and 120 Guests are viewing this topic.
Mk1
@altrez
I have found a way to have light mode and charge mode at the same time !
I posted it in my last post Dummy toroid!
gadgetmall
Quote from: TheNOP on May 27, 2009, 09:39:11 PM
the 1 farad kind should be enough for testing and do not cost a leg.
1 Farad Wont do what he want to do . I have  several 10 farads and they wont run a jt a day . Now if 1 farad is 1 amp then 650 farad is 650 amps . This is why it burns a stranded lamp cord in half instantaneously . You cant get 650 amps in a 2 inch diameter package no where for 55 dollars and youy sure cant buy a leg that cheap  ;)  I know these Super caps will run a jt for weeks and best of all it can be used for the Earth battery for real amp harvesting  rather than a tiny 1 farad cap that wont last a few hours .
Gadget
altrez
Quote from: Mk1 on May 27, 2009, 10:10:59 PM
@altrez
Yeah mine ls running 10 leds right now and charging at the same time :)
-Altrez
altrez
Quote from: gadgetmall on May 27, 2009, 10:20:11 PM
Gadget
Quick question how log does it take to charge one of those monsters :) I might buy one payday! Will it charge from a JT? have you tried charging it from 1 aa?
-Altrez
Mk1
@all
The Dummy toroid is so good i had to make a drawing !
I can put a heavy load on the dummy pickup coil without losing the high voltage on the regular secondary or changing the freq !
So one could light a neon or cfl while charging ! the circuit dose not consume more energy !
Edit altrez can you light one led and on neon at the same time ?
