Joule Thief
0 Members and 60 Guests are viewing this topic.
electricme
@Seprue and IST
Quote from: stprue on May 27, 2009, 01:24:09 PM
Very interesting and easy to build!
I just want to thank IST who provided this link and stprue for submitting this again.
I have just been enjoying a well spent couple of hours playing with all the electrical circuit simulators in this web site. ;D
jim
gadgetmall
Quote from: Artic_Knight on May 27, 2009, 11:43:31 PM
what the friend is saying about "empty voltage" is the same reason why i do not practice using a bedini motor.  when you send a high voltage to a low voltage battery you "artificially inflate" the voltage on the battery. basically the battery stores a higher voltage but does not have any amps to back it. the amps is required also to do work.
if you want to know if you have "empty voltage" in the battery measure the voltage of the battery when its fully charged from a regular charger. then discharge it and recharge with a bedini or JT to the same voltage and discharge again. time the discharge on both occasions and you will see what the true work is. if they are relatively the same then you have a full charge if they are different then you have empty voltage.
Artic it's a Misconception that the Bedini energizer puts out only Static voltage . True it does produce a static charge IF its not tuned  and you don't go ahead and build the rest of the circuit which KICKS up the KICK . a bridge and a cap and a diode is all that is takes to get CURRENT from a Bedini Secondary .All Mine have Current and all My bedinies can be Switched to desulfanate (pulsed) or Charge (Filtered kick)
Gadget
innovation_station
Quote from: gadgetmall on May 27, 2009, 11:57:19 PM
Gadget
i totally agree...
with out the out cap you got a reconditioner ...  ;) :D
ist!
and i think a surface charge is atained ...
i found my best chargeing results came from a full wave geramium diode bridge ..
i have used 4001 and 4007 bridges with much poorer results like 40 vdc .. the diff is in the resistance of the diode ...
use a microwave diode you cant go wrong ...  8)
i will make a bridge of them and see what will be ..
altho they love the kick and the speed  ;)
Mk1
@ist
What is up bros ! Is your keyboard CAPS broken ? :P :o
Good !!
Mark
Artic_Knight
anyways as stated before i will not use any other coil then a tesla bifiliar. case in point i have a jt running from 1mah from the origional JT make using 2 bifiliars and a .001uf cap accross the base resistor. id say its only half lit but hey maybe if i increase the windings or change the ratio we can improve. k now to go run off my earth battery :)
