Joule Thief
0 Members and 106 Guests are viewing this topic.
altrez
@all
the scope says 200kHz and the wave form starts large then shrinks like a wave hitting the beach its crazy. It looks like the volts are hitting over 30 at times!
-Altrez
gadgetmall
Quote from: xee2 on May 28, 2009, 02:35:21 PM
@ gadgetmall
With so many people working on earth batteries perhaps you could post some JT results you have gotten using the germanium transistors to convert a 0.2 volt input into a 1.5 volt (or more) output for charging the super caps. I think a lot of the earth batteries do not always put out over 0.5 volts and thus will not always run a silicon transistor JT.
. Hmmm . WE all i can say is the transistor i use are Mill Sec Us army and Rare . I test each one. As you know i am helping in a funded project for ASRF in The Black Hills and Expensive Data Recorders are being used along with Scientific Evidence of the Earth Battery  Length size spacing moisture magnetic ley declination , all the variables .. We are not allowed to use Germanium Transistors for earth Battery because this has to be totally replicable, part have to be readily available   and cheap . All My jts are using 2n3904 and 2n2222a can for the Eb project . some results were posted for altrez on My weekly  test . earth battery will produce over 1 volt using the proper materials . We are using eco friendly materials as  to not harm the environment  . We don't use lead cadmium etc.. I sell the germanium transistor for the low power jt projects to individuals that wan to run their Jt on a low output eb . A germanium requires that the toroid be would different . More turns on the primary ,lots more . The Frequency is not near the 2n3904 . once a good primary is wound then the ger transistor will perform as expected of  a germanium . Low input high gain . I personally have several Germanium Jts but there data is already posted . .20 volts .20 Ma. . with tweaking i can run on one .16 volts My eb put out close to 2 volts as high as 12 ma sometimes . Normal is 1.1 volts at 3-5 ma . You have to use a proper electrolytic in parallel with any eb . Mine is 3300uf 10volt low esr
Gadget
Gadget .
altrez
@all,
I think that lighting LEDS / Neons / CFLS form a JT is cool but what I am finding even cooler is that it makes one heck of a charging circuit. I think the LLA1 is going to be a sustaining charging device.
To drive / push my main Toroid configure 5 2.9" Toroid's all connected together.
I am now charging a small electrolytic cap with the same battery that is charging the other battery. This tells me two things 1. that I still have room to harvest energy and 2. That once I add the micro controller for switching it should be hands off :)
I want to thank you all for the great support!
Take care!
-Altrez
jeanna
lookey loo..
I just got 5 toroids and 1 rod.
They range from the size of a nickel US for the eyes to I think 2.4 inches for the mouth. Hi flux and higher flux u=60 and u=125 the big one is u=125
The rod is for a stubblefield generator. I will someday make just one more with this at the core.
jeanna
edit add
@MK1 these are pale green in their real color.
@Altrez. wow. good going!
altrez
Quote from: jeanna on May 28, 2009, 05:55:17 PM
lookey loo..
jeanna
edit add
Nice! Can not wait to see what you do with them :)
-Altrez
