Joule Thief
0 Members and 90 Guests are viewing this topic.
resonanceman
Quote from: gadgetmall on May 27, 2009, 09:56:56 PM
Not for a second . SOme Bedinies are ou / like mine ;) Have you checked out My video on a hard drive bedini with a piggy back coil . Well first this Bedini Bi coil puts out enuff amps to light a 130 volts incandescent lamp continuously  and this type of current has fried many Sla Battery already . It uses a cap to make the amps from the BEMF . Simple . This However Makes a wet Cell battery 10 time more efficient without the heat of a hard charger using one diode and a cap you still get a pulsing from the output . a bridge and a cap no . Its Filtered  good and converts all the pulses to dc amps There is probably still a trace of a induced pulse from the components being so close to the coil however .The Piggyback coil alone keeps the Primary battery hot at all times . It Is a wet Cell battery . The Piggy back current it over 80 milliamps . the Bedini only takes less than 20 ma to run . I am Proud of it and i dont even care if anyone believes it or not . All i care about is its OU to me and i Charge every battery i have with it for free . even non rechargeable . 40 or 50 times before they rupture and leak .
Aaltrez . your friend does not know what we are doing . you cannot light up 100-400 leds with a dc to dc converted running on one volt . I think not . you need the ac we are getting from the BEMF . that's the key to our energy . We are capturing the OFF voltage . thus the reverse dc pulse make it look like ac. The Charge you are getting is Real if it was dead to begin with and thus you are recharging it and using it by swapping it so its a real charge . Other wise if you only had one battery and ran just lights . when its dead its dead . now to have a way to capture the wasted voltage and store it . I'm an Electronics technician and  for 30 years have been repairing everything down to the component level and i know first hand when i build My first bedini that the whole story was never taught .They  teach you that when you put x amount of ac in a transformer that has say two secondaries that it splits the current  between the two but they dont tell you you can harness the heat  and make electricity from that with a pelteir module or that you can capture the Rf Field with other coils and germanium diodes and get power from that . or the fact . Just a few things i had to learn on my own .  The Charge on My E-lights is real . I took a 3 battery system and turned it into a one battery system and it still does what it was intended to do ,Longer light now and PLUS it recharges another battery so you will always have a battery hot . I can tell you i have ran my design over 2 weeks flipping and she still lights up all night . , This is not Normal Electronics operations . This is something else not on the market for a good reason . It would upset the economy to have everything power itself so they say . I don;'t care about the Economy . I care about having  free energy and keeping the money in My pocket for food not stinking oil and Nuclear power plant Misers  . If i build it and i see it does something nothing else will then i have accomplished a bi of that and did not hurt any one  and in fact saved money from buying two more batteries  .;)
@ I have said it before the Jt is an RF source , a transmitter also rather than a transformer alone and you can light up neons and tubes and leds with 1/100 the specified power that was required to light these devices with RF a form of ac  .
Gadget
Gadget
I  have not seen  the  video  of your  bedini .......or any of the other  videos here  lately
I have to make  do  with a very slow connection  right now .
It is so slow that  this site  usually times out  once or twice  before I get a page to load .
Videos are out of the  question .
I do  know that I am missing alot  because  I can't  watch the videos .
That is just the way it is .
gary
resonanceman
Quote from: nievesoliveras on May 28, 2009, 07:36:46 PM
Thank you @resonance man !
Long way we are from the elctrinium topic!!
Lady @jeanna
I have it working and charging another battery at the same time. Both batteries are very old and does not hold a charge.
I am testing if this circuit repairs this batteries, so they can hold a charge.
Jesus
Jeasus
What kind of batterys are they?
I have had good luck reconditioning  a sealed  lead acid battery from  a UPS
It has sat  for  at least 3 years  ......its voltage was down to 4 V
I  trickel  charged it  with just a cap  (1uF ) and bridge
It  took a couple of weeks  but  it  seems to be like new again .
I am  currently trying  a Ni Cad  for my  drilll      It  doesn't seem to be helping it  any .
gary
altrez
@all
I have just went past my starting voltage from Monday!!! And the source battery is not losing charge in fact it has went up 5 mVs. I have also been charging a cap and it has went up to 4 volts!
This all started happening when I hit the right frequency on my setup and thanks to jeanna who showed me how to check that seems to be 200kH.
So it should be extremely easy for anyone to reproduce my results. And that is my goal in this. I want to make it so easy that someone with no knowledge of electronics can make it work with parts that can be found just about anywhere.
If we keep pushing we can do some wonderful things.
-Altrez
gadgetmall
Quote from: TheNOP on May 28, 2009, 07:10:30 PM
AC is a modulated DC
it can be an amplitude, frequency, modulation and both.
the rate also be modulated and mixing is possible
i don't deny the AC waves complexity. there are infinite possibilities of shapes and rates variations.
but it still is a "tweaked" DC
can you give example of this : ?
the only things that are "undiscovered" about AC is its interactions with various materials that are not commonly used(read as "have not been tested yet").
i agree with everythings you wrote.
your intent was not misunderstood by me.
i am even happy to read your explanations.
i did not remembered the exact way electrons were moving relative to the polarity, that is why the remark and question mark about the holes.
even if the electrons movement come after the fact, i think it is still usable for the sake of describing that the flow goes from one side to the other then back to the start.
the holes myth came about for 3 reasons.
-guys like me, who were teached with the "holes" stuff, for the sake of simplicity as you said, talking about them without mentioning one basic fact, forgetting that not everyone had the same education.
see below.
-the student not paying attention at a critical moment.
-or an omition of the professor. :(
my prof teached us that the holes were not actually real holes. Duh!
they are "places" where electrons have a pre-disposition to go for start orbiting an other atom.
this is not the real explaination.
it is what i made out of what i was teached about it.
there is a reason for teaching us the holes stuff, the complexity.
a knowledge that is not critical unless you intend to do physic recherches.
thanks for you post, that reminded me my old time.
@all
there are a few other things like that, that are only fully teached to those who take advanced physic classes.
even for an electronic technicien or EE, it is not required to know the exact process that make the electrons move to do a good job at repairing or creating new circuits.
unless doing physic researches, those knowledges are not needed.
it is wrong to say that those knowledges are not available, because they are.
you only have to search for the right things by theirs names.
note that those are theories, not laws.
the direction of the electrons, or, of an electric current are use in multiple laws formulas, but it is rarely needed to know the underlying process of how that direction is established, it is enough to know in whitch direction it goes.
regardless of the direction convention you choose.
it is either the reality or it is its mirror reflexion.
it is a paradox because even if it is a mirror reflextion, it is still the reality.
when you look at yourself in a mirror, is it you or something else ?
there is nothing in the reality that is not also in its mirror reflexion and there is nothing that is in the mirror reflexion that is not also in the reality.
i think that it is the reason why nobody fully rectified Faraday mistake about electrons direction.
Yea i can give you an example of it . the TPU . mix more than two ac signals and what do you get . What if you mix 5 or 10 . Undiscovered .Anyways . take care . You seem to know it all .
Gadget .
stprue
Quote from: altrez on May 28, 2009, 08:50:46 PM
@all
It looks like we have at least 4 people now who have built self chargers :) This is so great and you know its just the start. I am working on my LLA1 and it should cost less then 250 in parts :) If you can picture a massive toroid in the center with the JT circuit in the center of it in a shield that part is extremely important. 6 coils coming off and a toroid on each of those with 4 coils coming off each one 24 connections.
test
All in a circular formation with 4 focus beam points on the out side all pointing at the center. More on the beam to come later. Lets just say I got the idea from TheNOP Thanks! you seem to be right RF is the key! :)
test
Hard to explain! Oh and now I am running a second config to make sure I could get the same results. I will post my progress!
-Altrez
