Joule Thief
0 Members and 41 Guests are viewing this topic.
stprue
@ all @ Jeanna
Ok I get it thanks for the help!
@ Pirate
sorry for wasting space please feel free for deleting my test posts!
Artic_Knight
so if a tesla bifiliar coil is used as a pickup it converts to amps its like a self made step up/down transformer. no it will not work without a primary and secondary.  if its used to put voltage in then it steps up the voltage. since the coil on the base of the transistor needs amperage to open the gate we can make that a a small bifiliar and with the large bifilar connected to the collector it will dump a high voltage.  if you make your third winding a regular winding and have it dump into a secondary torriod as a step up in a bifiliar then have a pickup of a regular coil you should get the highest voltage potential possible with the given current.
electricme
@stprue,
Thankyou, I have been wanting to do this for a long time, but I had to wait for my supercap.
Quote from: stprue on May 28, 2009, 10:39:44 AM
Nice work I knew it could be done. ;D
jim
electricme
@IST,
Arrrrhhh the feeling lol, yes, I might take a look at Mr Walton and Mr Crockcroft he he. ;)
Quote from: innovation_station on May 28, 2009, 11:11:36 AM
@ JIM
YOU BET YA!!!  ;)
GREAT WORK BRO   8)
I HAVE HAD GREAT RESULTS USEING THOSE SAME DIODES ...  HIGH VOLTAGE HIGH FREQ!!
NOW
WHERE YOU WANT TO GO ...  :)
CHECK OUT HOW A CASCADE WORKS ...   :)
LETS SAY WE HAVE 5 DIODES AND 5 CAPS ...    SO IF EACH CAP WAS 1000VDC ... YOU WILL END UP WITH 5 KV...
WITH DIODES INBETWEEN ...  LOL    ;) ;) ;)
WHAT WILL BE ?!?!?!?!  O YES I DO KNOW DAMM WELL
LOL
OK THEN WE GOT US A SPARK GAP LIKE A STUN GUN ....  LOL
RIGHT BUT AS A SPARK GAP WORKS ON DISTANCE SO DOES THIS ...
TRICK IS THE BLOCKING DIODE ... SO WE DONT LOOSE OUR RESEVRE ...
WHEN THE 5KV CAPS ARE FULL  THE SPARK WILL JUMP AND DUMP TO THE COIL .. BUT THE CONSERVED POWER WILL REMAIN ...
LOL
YOU WILL ONLY DROP 500 V THERE BOUTS .. AND YOU GOT ALL THAT 4500VDC PUSH POWER YOU ONLY TOP IT UP... TO DO IT ALL AGIN ....
NOW TO RECTIFY IT ...  AND MAKE IT USEFUL ..
THIS IS SOOOOOOOOO  TESLA LOL
IM NOT SURE MANY KNOW BOUT THIS ...
IST!
Yep, now I need to get a handful of supercaps, charge them in turn and connect them in series and BINGO, I got more Free Energy from the Earth Battery. ;D
I will need a High Voltage switch transister, or just mabe a simple mechanical pulse relay to switch contacts from Parallel to series, hmmmmm.
I could get a 2 hour run outa them, but it would take a week to charge this setup.
I need to upgrade from Copper rods and Aluminium electrodes to Magnesium and Carbon ones just like my friend Bill (Pirate88179) has done, then it will accellerate the recharge process.
Nice poetry ist, I see you have a mallable heart. :D
jim
resonanceman
Quote from: electricme on May 28, 2009, 12:40:17 AM
@Resonanceman
I think I have a couple of solutions to increase output.
I have been working on a series parallel circuit to beef up the output of the  JT in current only.
My theory is, the JT output streem can be presented to as many secondary (separately wound) toroid's as you would want to put into the circuit.
By paralleling the outputs you double up the current available from each toroid.
For example only, if 1 secondary after rectification is a .5amp, then having 10 separate secondaries
wound on 10 separate toroid's will give a total of 5Amps.
The primaries are "all" connected in "series" the output secondaries be rectified with full wave bridges, all these bridges + & - outputs be coupled in Parallel.
Another way would be to have a JT output presented to all the primaries in parallel, then make an identical second stage as I described in the above sentence.
Yes there will be losses, as in any system, but I hope to minimise that.
I have presented the following jpgs before.
jim
Jim
Yes what  I am  doing  is  almost  eaxactly  like your drawing
The  biggest  difference is  you drew it  with  normall  coils     I am using  my  LM JT  coils .......  although  I  wire them  up  ignoring the  2 leads  that are connected ..........so in effect it puts the   JT primary wires  in series
One of my plans is to start  with  a standard  secondary ..... a full spool  of  red radio shack wire ........  then  I am  going to add a primary and  tune it  this time  .......so far  I  have  used the  coils  that  I have already made up for  other things .
I am thinking of  tuning my  JT for  low power ......then  tune the   other   coil for  max   power .
The   Jesus mod to the JT  is another  thing I want to try soon ....... it seems to me that it will be much easier   to get  a  good output   from my circuit if  the  JT  is   self powering .......or close to it .
gary
