Joule Thief
0 Members and 41 Guests are viewing this topic.
jeanna
Quote from: Artic_Knight on May 29, 2009, 10:41:05 PM
did i hear that the earth batteries are resonating at 2.4MHZ ?  you know the resonance of water is 2.4GHZ which is what microwave ovens use to heat water and thus food! i wonder if theres a connection here as they are strangely alike.
I thought the resonance of water was 42,800Hz.
I get THAT all the time with my little ones made with the tor-23.
I haven't set up the tor-23 with the steel plates yet, but I will.
I just wonder how much the plates will change the frequency. I don't figure it will matter, since it is so easy to change the frequency with a pot or the number of turns.
Yes, I got that on my scope a couple of days running. It has the appearance that gadget's buddy gets in a carolina, so I thought I should post it.
I don't know about anything but radiowaves being in the 2.4MHz range. I wasn't even sure I wasn't picking up radio FM. Gadget can correct me on these frequencies. He is a radio guy.
jeanna
altrez
@all
Well I have been running now on the same set of battery's for 5 days now :) I have noticed that I can also fill caps while charging!
I have went higher then my starting volts on source battery :) So now i am moving on to charging 3 AA's and a CAP with a load as well :)
@Mk1
I watched those youtube videos and that seems to be close to what I discovered with to toroids running at 200 kHz
@jeanna
If you take two toroids and wind them exactly alike they will resonate with each other. Use a 3rd toroid or signal generator to push one.
Mk1 posted a link to some videos that show what I was trying to explain earlier:) I stumbled across the same thing by accident when setting up a second self charging rig.
Take care all!
-Altrez
xee2
@ Mk1
Quote from: Mk1 on May 29, 2009, 11:17:44 PM
@all
Again for those that did not see it yet ! Even Stefan commented it as 2:1 overunity  .
This can work with the jt , gadget know !
Mark
http://www.youtube.com/watch?v=kQdcwDCBoNY&feature=channel_page
http://www.youtube.com/watch?v=Idey7O0WlU0&feature=channel_page
http://www.youtube.com/watch?v=5Xefg-EfC4Q&feature=channel_page
This another example of someone coming to crazy conclusions because they do not understand what they are doing. There is no power gain. There is only misunderstanding. He needs to spend a couple of years learning AC circuit theory. DC power equations can not be used to compute AC power.
xee2
@ Artic_Knight
Quote from: Artic_Knight on May 29, 2009, 10:47:59 PM
@jeanna
this is the tesla bifiliar i use, its created by using one wire, folding in half and winding it a number of turns then cut the fold in half, join the output of one coil to the input of the other and you get 2 coils side by side as one coil, is this what you are using jenna?
This is a common two layer solenoid coil. I do not understand why you call it a "tesla bifiliar". Using uncommon names for common things only creates confusion as to what you are talking about.
Great drawing. It clearly shows what you are talking about.
innovation_station
quick comment on 3 freqs ...
your not ready for this in the   coils u have in my opinion ...
but truth is i never tryed ...
tesla says  no problem ..
will it work the same as my tpu tests ... nope i dont think so ...
when you master 2 freq then do 3 ...
2 freq will severly hurt you ...  ;)
but scaled a wee bit more than you are useing now ..
with some magnets ...  ;)
also you will find it intresting for those with eyes to see this came  from  carveings in stone posted in the lotr thred ..
now i just so happin to find some more ...
and i choose to share with you to move you forward to the truth ..
to where do both pos and neg turn there heads ?!?!?!?!?!
ist!
