Joule Thief
0 Members and 64 Guests are viewing this topic.
resonanceman
I  have been  playing  with my  Jesus JT / charger
It  took  a while  but I got it charging again
One thing I observed  many times .......when you  add a larger  cap to the base  resistor  more current flows
I was thinking that    larger current flow per pulse  is a good thing for a charger .
I tried  adding 3uF  to  the tank
At  high  power  settings  I can not  get  it to charge .
When I cranked the resistance up  high enough that the  current from my battery read 0  the  I noticed that the voltage of my battery was going up .
I would say that it is  going up  several times faster than it was  last night .
The output of the secondary  on my  JT is 0
I  left  the LED in the original  JT  spot  to  help  see what was going on ...it is flashing  maybe  twice  a second ........ it is irragular  but clearly  speeding up as the battery  voltage  goes up .
I just noticed something.
I said that  the output on my secondary was 0
Then I noticed that my 5 LEDs  were still connected .
The  meter  I  use for my output has a high/low  function
The high without the LEDs  was 3.7 V   the low  was  .01 V
There  was no light at all from the LEDs
altrez
Quote from: resonanceman on May 30, 2009, 03:31:15 PM
Nice work! I am seeing the exact same thing. My leds are flashing and my meter is going nuts. The battery is charging fast and all you need to do is increase the resistance.
I have been running a week now :) With my LLA1 setup and it seems that from the time I first posted  my success to now quite a few people are doing the same thing as my design.
-Altrez
resonanceman
Charger /JT update
I just tried adding  a 5MFD run cap to my tank
I was able to get one of my LMs  going .
Although  it is not  quite charging  it is running  with very little power
I am  lighting my 60 diode array .   it is not  bright but  it is lit up .
The  battery current is only .03A
It  has  taken between  .09A  and .14A to light this array with  a "normal "
JT
I wonder  if  I have something wrong  with my setup
I tried to see if  I could  get just a little more out of it  by removing the original  JT LED  my array went out   The  current  dropped to  .01A
gary
altrez
@Gary
You need to keep the load at a constant rate in regards to supplied voltage. I added a rheostat to one pickup coil and can adjust for the best load. Woks great! The key is you need a certain draw to get the charging effects.
-Altrez
resonanceman
Quote from: altrez on May 30, 2009, 03:53:27 PM
-Altrez
Altrez
I must have missed some posts
I don't remember  reading much about your  LLA1
Can you post a link to  some of your posts about it ?
My  description of my LM1 is   reply 5749   that is  back  on   page 575 if your  pages are the same as mine .
I have been running  my LM  for  about an hour now .
I added  1 extra  LM in  series with  the   LEDs
The  primary  added  about  1 V to the  output.
The  battery  voltage  has only lost .003V  in an hour .
I would add another  coil or 2
I am sure that I could get it  charging .........but all my  alligator  clips  are  tied up in the charger part of the circuit
I guess I am going to  wire it up on a circuit board
gary
