Joule Thief
electricme
@Altrez
Looking for measuring equipment
Quote from: altrez on June 01, 2009, 06:52:26 AM
Please let me know if you run across any good deals:)
-Altrez
Hello Al, I usually buy the good equipment from either of these mobs here in Australia.
The following three have once a month specials, but you have to make enquiries to see if they actually will honour the yellow flyers, as I discovered a month ago.
DSE (Dick Smith Electronics) Jaycar, or Altronics.
DSE, Jaycar and Altronics, all three at times have "specials" in the Silicon Chip electronics magazine.
DSE       = http://www.dicksmith.com.au  :)
Jaycar    = http://www.jaycar.com.au      ;D
Altronics = http://www.altronics.com.au   ;)
DSE has moved well away from electrical components except through their major stores, so I tend to go to Jaycar for components, Altronics for me is a pain as they don't have stock on shelves, (a bit like Tandy here) also the head honcho in Toowoomba tends to barge past his salesmen to seek out customers which I find intimmidating. ::)
Hope this helps.
jim
altrez
Quote from: Mk1 on June 01, 2009, 01:44:00 PM
@Altrez
Nice work there , so i see a dummy type mode , so tell us more on the small toroid you use .
Mark
Thank you Mark. As far as I know I am the only one who has setup this configuration so if anyone uses this setup in a charging system please give me credit :). It is basically a radiant energy receiver. By attaching one leg of a pickup coil you can tap into its power. Or you can amplify its power. I first posted about this around 200 or so pages back lol :)
I have been using this for a long time but just now got it to work well. when properly tuned it adds the voltage spikes from the field that is being pulsed / generated on the big toroid. It is very exciting stuff. This is just one of the ways I have been recovering excess energy from the JT and pumping it back into the system. For more charging effects.
If you look a this pick you can see it a bit more clearly. It has 4 wires or antennas that come from the small toroid that hove above the big toroid. It really works at least for me. It is hard to get tuned and I could not prove it until I got my scope. I have seen 50+ volt spikes of energy when it is tuned at the right spot above or beside the big toroid.
I have moved it away from the toroid and the spikes go down to almost nothing. At first I figured that I was just picking up AC spikes on the main pickup coil and in fact I am but this adds to the effect greatly. It might be a combination of things but i am still running on the same batters and charging a third and running a small load.
Give it a try and you will see that it works :)
Take Care,
-Altrez
altrez
Quote from: electricme on June 01, 2009, 08:33:21 PM
@Altrez
Hope this helps.
jim
Thank you Jim.. I will be on the look out. I plan to work 60 hours a week all this month so I should have some extra cash to buy a new meter.
-Altrez
Artic_Knight
Quote from: TheNOP on June 01, 2009, 01:06:51 AM
well, it can't be over unity since not even a unity is inputed in the process.
for me ou is: using energy to create more energy.
i am not talking about the energy used to make the materials here.
i am talking of a force applyed to create a greater force.
a heat pump is not a ou device, yet they have a cop of ~4
the energy is not created by the pump, it is already in the air.
the heat pump is only displacing it.
since you are not creating the energy it can't be ou.
beside heat pump there must surely be other devices able to displace energy while in operation.
call it what you will but if it quacks i call it a duck.
in the case of the heat pump they say its 300% effecient (i think that figure is for geothermals) and i say anything over 100% is over unity. the only down side is i dont think the boys figured out how to tap it for raw current. or if they did the documents got sequestered in a vault somewhere.  how can you say a unit has to be over 100% effecient and not aknowledge a unit that has made it even though it only deals in moving temperatures? if you move a electric force at over 200% effieciency from one battery to another is that not considered OU?
Artic_Knight
Quote from: Mannix on June 01, 2009, 03:21:38 AM
Energy can and is converted from one form to another daily that we can see and have an agreed understanding.
The terms "Overunity" or "Free Energy"   Require the user to NOT understand the forms.
is that the case or is OU getting more out than you put in? doesnt mean it doesnt come from energy somewhere just means you put in 1watt and get out 2 watts,... somehow along the way you picked up energy from another source that you were not supposed to but did, and thus it came from somewhere.
