Joule Thief
0 Members and 92 Guests are viewing this topic.
Pirate88179
@ Wilby:
Thanks, that is good information.
@ All:
In case any one else want to get some super caps: http://parts.digikey.com/1/parts/90424-capacitor-ultra-400f-2-7v-radial-eshsr-0400c0-002r7.html
The above link takes you to digi-key and a 400 F Cap.  At the bottom of that page are links to many other sizes and values.
It is interesting to note that you can buy a 5,000 F super cap on their site.  I believe it costs a little over $4,000.00 but, I didn't even know you could get one this large.  They have a good assortment of 1,5,10, 50, Farad caps at decent prices.  I plan on buying some larger ones later when I can afford to.  (Not the 5,000 F cap, too rich for me)
These caps seem to work like batteries.  They do not just "dump" everything all at once.  I have a small supercap I have used for over a year.  I can instantly charge it up and it will light an led for over 2 hours on that one "flash" charge.
I feel like we can incorporate these into our JT circuits in some way.  I have already used the supercaps by charging them with my earth battery.
WilbyInebriated
your feeling is correct bill, although i think if you want to stick with the boost circuitry you have been using, you need to mod it a bit to lower (buck) the supply (5v supercap) by placing it in series with the load and feed the 'extra' back to a smoothing cap
timmy1729
Quote from: WilbyInebriated on January 02, 2009, 06:03:50 PM
HOW THE CIRCUIT WORKS
that's how it works, as simple as that. no puzzle at all.
It's no puzzle at all unless you are electrically challenged, like myself  ;D
Thanks for the explanation. Now I have to find an electrical engineering dictionary so I can understand it LOL  :D
timmy1729
@All
I went shopping this afternoon and got some silicon and zener diodes to experiment with some more JT improvements from http://wiki.waggy.org/dokuwiki/electronics/joulethief .
I also got a Darlington transistor to try out that idea posted earlier. I don't know what was planned for the darlington setup, but if someone wants to tell me what to do with it, I will test it out for them.
Mk1
@Timmy
Connect the transistor the same way you usually do , assuming that regularly you are using a 2n3904 npn if its a pnp transistor just reverse the battery that should do the trick , you may need to play with the resistance to make sure there is enough to make it switch, if at first nothing happen try a 9 volt battery to see what its doing .
