Joule Thief
0 Members and 133 Guests are viewing this topic.
Mk1
@jeanna
Is your jt in attracting mode or repulsing ?
And
Sorry, You can do that. You won't get me to do that again, for sure!
I an not sure what it means ?
If it means its to hard , you just need to connect it one time ?
And i am curious to know the difference in result , if the give different results , then ??
I know you did good so far but you are still new at the scope thing , also not everyone got those ...
So i still don't get it.
Mark
In my experience , taking a 2n3479 and a 2n2222 , and tuning the pot i get better with the 2n2222 same jt setup. even better with 2n3055
innovation_station
its the off times ... lol
of the sw...   lol
hence why 30vdc is needed for fets ....  ;)
ist!
Pirate88179
I am posting this here because it is a good site for folks to have.  I use it all the time.  This is a calculator to determine the magnetic deviation and also the magnetic dip angle for your area:
http://www.ngdc.noaa.gov/geomagmodels/IGRFWMM.jsp
This works all over the world and even if you are not ever going to make an earth battery, it is a good site.
TheNOP
Quote from: electricme on June 09, 2009, 09:11:10 PM
If we put a tiny current pulse into the toroid, via the JT circuit, then we will only get a small magnetic field to work with.
If the same toroid was hit with a more intense jolt of current, I would expect a more intense magnetic would circulate inside the toroid.
yes
the way the jt make it oscilations is primarly what prevent a higher current to flow through.
the impedance come second, but it is what make the biggest difference since the oscilation method does not change from one test to an other.
i am waiting for my timer chips to arrive.
i will try to make it work with same 1.2 volts battery to make the oscilation.
i might not be able to do that at 1.2 volts tho, but at 3 volts, it should work.
altrez
Quote from: electricme on June 09, 2009, 10:34:02 PM
@Altrez,
Just take the tape measure and go from ankle to knee, (half a leg)  ;D
jim
hahahah that was great! :):)
