Joule Thief
0 Members and 150 Guests are viewing this topic.
gadgetmall
Quote from: jeanna on June 10, 2009, 08:17:12 PM
@MK!
I cannot understand those concepts yet. I have made a drawing that represents the primary in the jt I have on the biggo. It is not like either of those choices you gave me as far as I can tell, so...
Please feel free to change it and annotate it to explain, if you want to.
@xee,
Thank you, but
I didn't expect a comment about the pickups.
I meant the primary where the larger number of turns is on the base and smaller number is on the collector. and wow it is way bigger in output, but before on other designs or whatever... the opposite was true.
I knew you were working a theory about this. That is why I thought you would comment.
@Gadget
It is a 2N3055 It is printed with RCA on the front.
I corrected the phase?
thank you,
jeanna
yes remember i told you there are 6 ways to hook up the primary Jt . for example . : two wires wrapped the same time . the beginning  is 12 the end of those wires are 3 and 4  . ok . we can hook 1+ 3 together and then switch the wire on  B an c  with 2 and 4  thats 3 different ways then we could hook up 2+4 together  and switch 1 and 3 between b and c . thats 3 more ways . 6 total . In the 6 ways you will find the correct phase to run secondaries in series and obtain gain rather than cancel . . BTW secondaries have 2 more phases as well . Confused . hehe . you do get the point though ?
Gadget
Mk1
@jeanna
I modified the drawing a bit to look at the field lines created in the toroid by the jt coils.
@gadget
The 2n3055 seem so work better at low hz , slower is key with bigger toroid.
jeanna
Quote from: gadgetmall on June 10, 2009, 08:33:40 PM
Gadget
I thought we were just talking about the secondary. The pickup.
Here for a review because it is so many words
90 +90 = 80
90 + 90 = 12
boo hiss bad
that was yesterday until I put the many turns onto the Base coil
90 + 90 = 192
yeay
But ta da today...
90 + 90 = 450
OMG!
The 2 differences were more winds on the base coil
the transistor was changed to a 2N3055
So, is that phase?
jeanna
jeanna
Quote from: Mk1 on June 10, 2009, 08:36:05 PM
@jeanna
Thank you, Mark,
Now, is there a way to say what happens with the 3 directional  pickup as you do it? When added to this?
The thing to add to this question is that the ends of my pickup are starting and ending on the bottom of this drawing. (there were reasons, but I want to be sure you realize this)
jeanna
Mk1
@ Jeanna
Some more to get a better picture.
Yes i realize It !
