Joule Thief
0 Members and 168 Guests are viewing this topic.
electricme
@Xee2
On the below circuit, there may be a tendency for one of your transistors to get warmer than the other if they are not identical, eg if from a different batch, one of them might have thermal problems, the hotter transistor will be caused because it is taking more of the current/load.
If you place a 1 ohm 5 watt resistor in series on each Collector or Emitter, then the load will be  more equally shared.
jim
nievesoliveras
Quote from: resonanceman on June 14, 2009, 09:09:51 PM
The  schematic would  be  exactly like your  Improvement 1    except   that   I  used what  I had on hand ....  the transistor  is 3055   the  base resistor is a 100K pot
The  cap  is  1uF
I  guess the biggest  difference is   that  I  used my LM  coil .   It  has   an 8 turn  bifilar  primary   and  a 300 ft  secondary ( one  spool of  red Radio  Shack  mag  wire) #30
This  is not  quite  self charging  at least not at the   brightness  shown
It  MAY be self charging  if the  power is turned all the way down
gary
Thank you @resonanceman for the explanation !
Jesus
xee2
@ electricme
Quote from: electricme on June 15, 2009, 05:14:37 AM
Thanks. The separate base resistors should force equal power, with slight variation due to gain differences. Adding collector resistor would defeat purpose of paralleling transistors.
xee2
@ all
Note, any voltages I measured across a 15M resistor are wrong. This was a voltage divider and I had not used the correct resistor values.
stprue
Quote from: Mk1 on June 14, 2009, 02:32:09 PM
@gary
If you use firefox go get the add on called downloadhelper, that way you can download you tube for watching directly on your pc.
@all
just a reminder of the beast 16x140v output !
WOW so this things total ouput would be 2240 rectified DC volts!  Great work MK1 and nice clear pic as well ;D
