Joule Thief
0 Members and 119 Guests are viewing this topic.
Mk1
@nop
I explained last night why it works better , did you read it?
It will never double the voltage , that is a sure thing m8, all i am saying is it creates a stronger field , the gain will only be showed by the secondary .
Unless you have anything constructive , you can drop the subject , ok .
oui le coil peut etre comme un diviseur de voltage , chaque tour est comme une resistance , mais ca va pas changer le voltage c'est sur mon vieux. Mais le voltage est mieux disposer d un cote a l autre du coil , donc un meilleur equilibre entre les poles , c'est tout . Pour resultant le champ est plus fort. Quand meme je suit obliger de defendre tesla, come on !
On pourait facilement le prouver avec un tesla meter hummm..........................
ou gauss meter si tu prefaire , pourquoi pas c'est quoi le probleme !
Mark
jeanna
Quote from: free on June 17, 2009, 02:51:45 PM
just wanted 2 say i`ve uploaded ma first JT vid...enjoy : http://www.youtube.com/user/BiDaDiKuNuKu
Hey Free,
I was not able to see more than 1 minute on your utube video. It kept loading but stopped showing or progressing.
Maybe utube changed protocol recently, but I watched a couple other ones just to check that I can still watch and I can, so, hmm?
jeanna
Mk1
@gadget
My question concerning the mobius was to see if any difference could be done with it , it seems to be working nicely the way you used it , but my next move will be to make mk with a regular coil on one side and a mobius on the other , i will put a cap on one pickup coil with the volt meter on the opposing coil to see if the voltage drops to the cap value like it usually dose, if not then mobius it will be even if the voltage is lower .
@all
For faraday , a coil could be added to change phase , or one wire load from bifilar pickup coil one end of each coil to ground (earth ) or not connected. Or even a mobius the tpu elite say that it will not see its load.Needs to be tested.
But you can really do it with a dummy toroid.I tested it , i will be making on soon with the neon and triac battery charger, with high voltage on the main toroid , it should be a regular mk.
Mark
TheNOP
Quote from: the_big_m_in_ok on June 17, 2009, 04:36:17 PM
>>I did have another look at the schematic in question.  L3 is broadly parallel with both sides of the bifilar JT transformer.  And, I finally   ::) ???  noticed the diodes are backwards to block current flow to the positive plates of the caps.
Never saw that before.  It's so new to me that I don't know what effect it'll have on the rest of the circuit.
the components in the red square and the L2 can be replace with an other way to trigger the transistor and the results would be similar.
but that is just my opignion.
stprue
@IST
How's your phase shifting coil working out?  What type of results have you had?
