Joule Thief
0 Members and 182 Guests are viewing this topic.
innovation_station
i used the 2222 and it only lits brightly if i hold the bulb ..
i used a 4401 same result yes it does lite without touching it but it is sooo dull  still no diodes
might just be a freq thing now ...
ist
but yes mark the 3904 did not do a thing for it
Mk1
Quote from: innovation_station on June 30, 2009, 01:15:18 AM
ist
It look like its searching for a ground , try a neo , or one wire lighting  grounding the other end of the tube.
xee2
@ jeanna
Quote from: xee2 on June 29, 2009, 04:59:27 PM
@ jeanna
If your want to run a fluorescent tube for a long time I would suggest using a lot of turns on the pickup coil so that you will be able to generate the 400 volts needed to light the tube with a lower battery drain.
I think Mk1 is making the same point.
innovation_station
by changeing the resistor with a 1 k pot and useing a 2222 i got it in perfect sine wave at 500 v peek to peek  still not enough diode time ?
but even if it dont lit the cfl i was thinking of useing some inductors from the cfl curcuits ... 2 of them   and wind a 3 or 4 turn primary on them they have thousands of turns on a feroite square rod
...  and up the 250 v half wave to what ever i get from the inductors as a transformer ..
might that work try it tommorow ...
to late tonight
peace !
ist!
Mk1
Quote from: xee2 on June 30, 2009, 01:40:43 AM
@ jeanna
Hi xee you managed to understand what i said . Cool  ;D
Keep the good work !!!!!!!!! thanks
