Joule Thief
0 Members and 103 Guests are viewing this topic.
resonanceman
Quote from: WilbyInebriated on July 01, 2009, 08:24:47 PM
thanks jeanna, glad the link helped.
@resonanceman
very small bobbin cores can be used with good success. i have a jt using a bobbin core that is a bit smaller in diameter than a AAA battery and 1/4 the length. i have access to a good camera now so if you want a close up of it, give me a shout.
WilbyInebriated
The  bobbins  I have are  about 1/2 X 3/4    I think  that is about as small as I would want to go
If  I use  magnet  wire  for the  primary  next time I should   have  a little more room for  secondary . .....maybe  I can  get by with  a couple less wrapps of the  primary  with mag wire  .
I   don;t  think I  will be taking many  pictures  until I  get  something  soldered together .
I use  alligator  clip leads  to connect everything together .......  It  takes   from  4 to  9 coils  to get to  a self  charge  state .....  I  find that  adding  another coil  often  gives me  between  a half volt  to 1 volt more ..... ( under load )
most of the time  I use  my LM coils  or  toroid JT coils ......  with these  I usually  connect  both the  primarys and  the secondary   for either  flyback or feedback .
So ....... you can imagine  how much of  a mess it  can be .....
I think my next  try  will be  with a flyback  transformer  core .
I remember  someone    used  one of these before .......
I am going to  try to  get  primary  secondary and   hopefully   one or  2 feedback  coils  all on there together .
after thinking  about it  a few minutes  I am     take  it apart  and    try to wrap about  200  turns on both the  rounded legs ........then I clip  it back together  and   wind whatever  I can on the   square  side ......
the last step is   adding  a MK2 primary .....  on the  ends .....  I guess my first step  should be to do a test and see how many  winds it takes   on each leg of the MK1 to make it work
gary
Edit
I  did not  try to  tune  it  ........but I am guessing  that 5 wraps each leg  is about right
It  lights  up  the  JT LED  at max  resistance of my pot .......2.5k      it  starts to sing  at  .70  A     The  pitch  drops  low enough it is hard to hear  at full power ...... 1.5A
Ooopps  ....that is with  2 batterys
jeanna
Quote from: WilbyInebriated on July 01, 2009, 08:21:51 PM
http://www.tb3.com/tesla/
Hi Wilby,
On TB3 site at the bottom of that page, there is a list of measured inductances.
Is there a meter for measuring inductance?
or, even better, is there a way to measure it with a dmm?
she said, hopefully.
jeanna
WilbyInebriated
Quote from: jeanna on July 01, 2009, 09:58:12 PM
Hi Wilby,
jeanna
measuring inductance or capacitance is difficult at best without an LCR meter.
not as far as i know of with a DMM (some can measure capacitance).
i like primary form on his mini tesla from that link. i hadn't noticed it before. thanks, i might do mine that way.
innovation_station
heres my latest unit only for led lighting ...  works awesome ...
ist
my newest toy
innovation_station
about my last picture see above ...
what if i took speeker wire bifillar thin gage ..  and did 3 turns around each and compleated the loop at the 6th coil then jt ed the pulse coil with a 3055 and never taped the jt flyback so it is forced out the 6 inductors as step up transformers then grouped all outs togather as one after rectifering
ist
just looking for comments
:D
yikes i may wind round and round and round then stop .....  hummmmmmm
ok im gonna use magnet wire .... bifillar
gonna use fone wire .. as primary
