Joule Thief
0 Members and 87 Guests are viewing this topic.
nievesoliveras
Quote from: resonanceman on July 06, 2009, 09:50:18 PM
OPpppsss
It looks like I made my Jesus  charger  wrong
It  works  good though.
gary
You did not do it wrong it is a perfect replica of my circuit.
What it makes it special on tour hands is the addition of the negative connection to it, that I does not use on mine with a pulse motor connected.
So I dont have to rethink the circuit to the negative side whatsoever, just connect the circuit between the negative and the positive poles with the diodes cathode mark to the positive pole.
Thank you @resonanceman !
Jesus
resonanceman
Quote from: nievesoliveras on July 07, 2009, 09:20:37 AM
Jesus
Jesus
It  was  a screwup  in  a way because I did think  I had it connected  in the same way that  you  did .
I am glad that  my screwup   has  helped  you
If I  remember right  you had a page  of symbols  for  schematics .
Can  you  post that again ?
The last time   I had not figured out  how to  use  the separate  symbols.
Thanks
gary
stprue
Quote from: innovation_station on July 06, 2009, 10:23:27 PM
no i never did ...
but your thinks ...  sounds good to me ...
can you build 1 ?   for everyone   bro ?
i like the copper as it is a pump of cold or returned or the GOOD STUFF...   that keeps getting kicked in the but ...  with a gate keeper and a few squeeze coils ...   plus it runs  on a aaa  ;D 8)
ist!
I have already started. 8)
jeanna
Quote from: stprue on July 07, 2009, 12:14:35 PM
So, what are you doing?
I believe this think tank works best when people think out loud. It also works best when we share all the stuff, successes and 'failures'.
I know you know this. It is just a statement.
So, what's new?
jeanna
stprue
Quote from: jeanna on July 07, 2009, 01:06:38 PM
So, what's new?
jeanna
I usually like to make sure my ideas work before I post about them but ok....
I believe it's an altered tesla design atlerations by me on an original idea but I'm not sure I found the diagram somewhere in this forum like 6 or 8 months ago and I can't really remember if the diagram I have is further altered by the original member of the topic.  hummmmm maybe it was that tesla patent 2277some numbers topic.  The original is divided into 4 sections but it's actually only two that cross over to the other side of the coil kinda like the x2 but on a grander scale.  Actuall picture an x2... the wires go to the other side for faster switching....now put the same set up at 90 degrees from the other....so 2 x2's with more windings....ok so my added idea would be to add in 4base coils and 4collector coils inbetween the 4 sections of the coil.  I was also thinking that this could be set up mk style but was not going try that first.  I will post some pic's of at least the 4 base/collector coils I have finished already but that's all I have done so far (this is on a biggo).  I have been looking at the diagram and to me it is starting to look like it is set up wrong and each side would cancel out the other so I think I  will make a small version of this before I start winding the biggo.
