Joule Thief
0 Members and 352 Guests are viewing this topic.
jeanna
Hi
I was just editing my post and I see this about dc
The pulsed dc is not the same as dc from a battery. We know this.
I think we need to be consistent, here, Tesla made the distinction between
"steady" dc and
pulsed dc
these were the BIG differences; and when he referred to the pulses he put them into the same category as AC. At least he did in the lectures I have been reading from 1892.
3 pm lunch time!
jeanna
resonanceman
If  I am  right  about the  rotation   thing .......some of the people here might have the  right kind  of coil for the job.
I didn't  make a coil  gun .......but I know some of you did .
What are the  coils for a coil gun like >
Could    a similar  coil be made  for the  collector  coil  of a JT ?
It seems to me that they would  give a pretty  good kick.
gary
Mk1
@all
I must stress this a bit concerning the mk4 tesla toy , the use of the coil and transistor .
First the coil are each 12 turns , the drawing is not exact for turns but is for winding direction .
OK now the transistor one is pnp and the other is npn , now i tell you this because the first time i did not use the regular 2222 or 3904 i made a jt that did not work unless i reversed the battery poles , so the negative is the common to both jt coil . That way i found it easy to have 2 jt one pulling from ground and the other from the plus pole .
And this is how i build it ,worked right away that was my third jt so the pickup coil can be improved quite a bit  base resistor value also ...
resonanceman
Quote from: jeanna on July 08, 2009, 05:58:47 PM
Hi
"steady" dc and
pulsed dc
3 pm lunch time!
jeanna
Jeanna
I agree
Pulsed  DC is  very similar to AC
Pulsed  DC  can  have  a rate  of change  that is  similar to AC
Pure  DC  has no rate  of change ..
gary
resonanceman
Quote from: Mk1 on July 08, 2009, 06:15:34 PM
@all
Thanks Mark
I see on my  data sheet that  MJ2955  is  the  PNP equivilent  to the 3055
That  would be my  first choice .
Abra  electronics  has them
It is possible that  tip2955 and  tip3055 might  be easier to find.
it looks to me like they are the same  transistirs in a newer  package .
The  data sheet  seems to be  about the same ........ I have  the Motorola data sheet .
Near the  bottom it says .
NOTE: For additional design curves, refer to electrical characteristics curves of 2N3055.
gary
