Joule Thief
0 Members and 94 Guests are viewing this topic.
resonanceman
Jim
Congratulations on your  Bedini.
Great work
Quote from: electricme on July 09, 2009, 08:43:50 PM
To make the JT run on a 9v battery just change the base resistor to the higher value. (you should get a few thousand volts out of it then)
From  what  I have been seeing  it is not  quite that simple .
I  do  agree that  changing the  base resistor  will  limit  the voltage to the base ......but that is  just the start .
I had hoped  that  I could  just  connect  my   LM coils to  higher voltage and  have higher power out .
It  is not that simple .
The  problem seems to inductance .
Our coils  are  efficient at 1.5V
At higher  voltages  they do  not have enough inductance
I have a 2.5A "leak" through my  C coil
I added  a pot for   compensating  for the higher voltage .....adjusting that pot  does not  change the leak much .
Tomorow  I  will  try  to make a  higher inductance  coil
Can  you take some  resistance measurements   off  the coils  in your cattle  prod?
That  would help give me an idea where to start .
thanks
gary
innovation_station
well the fun can be had with 2 freqs ...  lol
i got this beat freq and when i touch it it goes nuts and backfeeds to the led pulser ..  wild on the scope
almost like it knew it ...  lol
plus i wound my coil diffrently  5 laps 1 dirrection yes i get 1 dirrection spikes when going for spikes like i said a few pages back im NOT  after spikes lol  i want a ringgggging colapse ...  pulse train ...
lol now i got 1 ....  lol  :D
with spikes into the 150 v  and if i wound another wire in the oppsite dirrection   would i get positive spikes lol  :D
hummmmm
lol
to bad i cant make a short video ..  1 hell of a crazy bright wave when i touch it then it dances ... all crazy like ...
ist
here is a pic took 95 trys to get this picture
here is the coil
jeanna
@ist,
It will be interesting to see if it does go in the other direction as well.
It seems to be a trick to get this to happen.
Even this dblxx is very directional. The scope shot I posted is unusual. Most of them are densely packed one way spikes. If a fast rate of change is what you are going for, this is a really good way to wind.
EDIT:
Wow cool scope shot. 95 tries. there is some dedication!
I have seen that crazy shape many times.
I see it on the tor-23 a lot.
Now, I know what it looks like on a real scope.
Thank you. That is so cool.
On my scope, if I get closer, so to speak it can look like a camel hump with one tall hump and one short one.
What is the frequency of that wave?
@Gary,
I tried using a 3v battery (well it was 2.54v) on this coil and core today. The volts went from 34v DOWN to 28v!!
But oh my the frequency went from 250KHz UP to 434KHz.
I was very surprised. This was very unexpected..
@everybody,
I did set up my full bridge with 2 additional diodes and cap to see just what the voltage is.
Because at the scope resolution where there are 8 volts per division, the scope gave me a readout of 19.2v to 21.02v.
But at the resolution of 20v per division it says 34v.
I reasoned that the scope could detect a skinny spike that was too fast to show me, but it could tell me in the digital read-out section what it could detect.
The cap collected 16 to 18v right away. up to 2 minutes it was still below 20 v.
But I left the cap on for half hour and at that time it had collected 29v.
I am sure in another hour this would be near the 34v peak that the scope says is there.
I am delighted with this primary configuration.
I will fully wind a secondary and test it.
This ought to have room for 85 to 95 turns through the center... IF the cross wires do not take out too much space.
I have 2 others of this core size with 74 turns and I may make one with that so I have a really good comparison.
There are 4 pie shaped spaces in between the crosswires.
For this preliminary test today, I have kept the 14T secondary all within just one of the quarters.
I will be looking through the scope to see what happens to the wave when I move out of one quarter into another.
thank you,
jeanna
innovation_station
thanks jeanna ...
the pic was the wayyyyy easy part ...  just try to tune into the wave agin ...  i was useing a 50 k pot
the wave is easy if you touch but i was not touching anything i had it running like that 15-20 min
till i bumped it
but i got some vids but im not tubbing ....   :)
ist!
there 2 waves infact 3 but ....  ill say 2   first freq is fast to make my ringgg spike second intrupts the first ..  at a realy slow speed im powering the jt from a led from my dollar store chaser ...  i may make 2 more ...  then tune them all 3 right in to a 2 freq pulse train that rotates
this could be a controller for my last tpu ...   1 way i can do it ...
lol
BAMMMMMM
  i got it .....    lol   duh!!!  i feel dumb...  lol
put a neo on the toroide ...  lol    lol
now it is stable and easy to tune it  :D
wow now maybe it is just me but it seems to be accelerating ...  wild ...
the pulse seems to get going quite a bit faster ... than when it first started i never did a thing ...
the pulseing on my supply has not changed its speed
but my scope seems to be flashing faster
correction IT IS ACCELERATING ....  NUTS.....
i just blowen away it is going crazy ....  since when i started it ...  it has picked up the pace at least dubble time ...  ;D ;D
what can this mean ?
stprue
Quote from: innovation_station on July 10, 2009, 12:48:24 AM
thanks jeanna ...
till i bumped it
ist!
lol
BAMMMMMM
I'm lost are you talking about the prod you found or a JT coil you made x2 style?  I found the ansewer to this in the New TPU Build topic...Thanks!
