Joule Thief
0 Members and 144 Guests are viewing this topic.
xee2
@ stprue
Quote from: stprue on July 11, 2009, 05:25:58 PM
It pushing a little over 350vdc rectified with little tuning and messing with. 52 winds each side off the pickup and 10 on the collector coil/2 on the base!
32.2 Ohms off my 500 Ohm POT
2N3005 power transistor
Before you add the other side, could you check the output voltage using a diode and capacitor and then reverse the diode and see what the voltage is. My coils all give a very high voltage with the diode in one direction and a low voltage with the diode in the other direction.
Here are the results for my 2B-10C-80P coil. I would call your coil a 2B-10C-104P coil. They should be somewhat close.
Also, was your taransistor a 2N3005 or a 2N3055?
jeanna
Quote from: stprue on July 11, 2009, 06:54:03 PM
Sorry I know I never include this info.
its ok. I forget to say I am only using the pickup!
QuoteInput by protek powersupply ..
1.5 volts DC/.500amp
well, xee2 is not objecting, but I need to ask.
Is there any way for this power supply to sneek a little extra amperage into the circuit if it calls for it?
And, how could you tell?
I am still puzzled about why you have no trouble starting this up. or rather, why I do.But maybe a little surge is available?
Also, I will change the primary on mine to 2T,10T  because the pickup has 240Turns and would be very close to both of yours.
I may have better luck this time than before.
Thank you for your good work and beautiful pictures,
jeanna
jeanna
@xee2,
Wow,
Those are great tests. Thank you.
You answered many question in one little gif!
a gift of a gif.  ;)
And are you always using a ceramic cap here? You already told me it was OK to use the can type which is polarized, but I am just checking.
thank you. this is great!,
jeanna
xee2
Quote from: jeanna on July 11, 2009, 08:18:33 PM
It is always better to use an unpolarized capacitor if possible. I am using polarized capacitors for the battery caps and unpolarized at the voltmeter.
innovation_station
just cuz i like this coil ... ill add 2 more pics ..
this one has the mk2 transformer windings on it ...  next i will add the mk2 generator windings on it ...
i will dubble the windings on that one ..
soon as i get it wound i ll build the jt's all npn ...  but it dosent matter as i see it you need a second unit pnp doing the same thing ...  but 1 at a time lol
the windings showen will get rectified to a SUPER CAP  would be great but the only ones i had were small and sent out ..  :(
so ill just use some RECHARGEABLE BATTERIES...   and run from the source till they are charged then switch to them ..  and let the SOURCE recharge ..
the 5 mk2 generator windings are additional outputs...
ist!
i fininshed all the mk2 windings ..  there 10 mk2 windings on this toroide now ..  5 are transformers/ feedback coils ..  and the other 5 are generator coils .. output ...
and for my next wire act ....   :D  lol   i will add 22 ga magnet wire in laps 5 laps right ontop of the generators ....  ;D
then tommorow ill build all the electronics of it .... 8)
sure is a busy little cridder lol ......
