Joule Thief
0 Members and 87 Guests are viewing this topic.
stprue
Quote from: jeanna on July 13, 2009, 11:37:25 PM
Go ahead ist,
I like your pictures, and could you describe 4 x 4 better?
1 wire 4 turns? or 1 wire 4 coils of 4 turns?
Stprue,
I found this. You were once there at a tesla thread, but I just made a small screenshot of the 2 completely separate outputs which are part of the TRM patent.
Then I also noticed that after all that messing with the picture, I saw I had wound it wrong. Maybe that is why I had such a problem. I remembered it right but had it in mind to do it wrong! eesh!
It is a primary wound the way you wound the first half of your secondary.
I think I will wind a secondary as tesla suggests and have that on the inside. Then I can make adjustments to my primary as I need to.
here it is.
jeanna
Good good...I will try to wind the same only have an x2 c/b coil.  We can then compare outputs  ;)
innovation_station
well i found 1 more 1"  toroide ..
i was thinking why cant we dump the out of the jt back on the toroide?   ;D
anyone ever do this .. push and pull ...
cuz if your getting 30 v on the off... then why not compound that in the core and use as a transformer
maybe in the tesla design .. may work well  but then you want the pnp too RIGHT MARK?
lol
ist
it  ziz a dubble eathzer pump lol  and a transformer ..    sh!t does it spinn too .. sounds like biggo time .. soon  ;D :D
xee2
@ electricme
Quote from: electricme on July 14, 2009, 05:00:13 AM
@Xee2
Now do you mean I should put several caps in series or parallel, what values should I put there?
Remember its putting out 40volt, so the caps have to be able to soak it up without spillage.
I can see a few hours scrounging through all my caps coming up he he.
Thanks Xee2
jim
I am very suspicious of claims that circuits are putting out more power than they are using when there is a battery in the circuit. If the circuit is generating more power than it is using then it would run forever without the battery. Replace the battery with a charged capacitor (any value) and see if the voltage on the capacitor increases or decreases. If it increases without a battery in the circuit, then you have shown that you are getting more energy out than you put in.
stprue
Quote from: electricme on July 14, 2009, 12:33:27 AM
@Stprue,
That's what I'm trying to do, ;)    and the daydream bit toooo  ;D
To me it looks like someone has done it already with that new EB tesla transformer... If it's legit anyways.
stprue
Quote from: jadaro2600 on July 14, 2009, 12:47:30 AM
Has anyone tried a low frequency crystal oscillator on this circuit? ..and how would it's circuit diagram look?
I've thought about a crystal cored design, i'm just at a lack as how to use the crystal oscillator part; any suggestions?
Thats funny you mention this because I have been thinking about the same thing.  There is some stuff out there if you google it.  I think I have a small crystal oscillator but I'm honestly not sure.  I know they usually conect directly to the transistor.
