Joule Thief
0 Members and 185 Guests are viewing this topic.
innovation_station
i think i have decided to to my big go as i need a NICE DEMO UNIT ....
so i will do much similar to my 5555 coil but a big one and i will add jims mod to it ...
i will wind 7 primary wires ...  1 will be constant powered ... (fundamental) ..
then the 123 phase rmf design in 2 dirrections ..and i think ill only do 1 turn per ...
but i will use heavy gage wire  so i can go higher voltage and amprage on the input .. and on the ou put
i will use 3055 and 5871 cuz this is what i have ..
but this is how it will work
i will sneek some juice  to charge a cap .. then feed the cap into the 7th primary wire ..and i should maybe use a bulb of sorts in that circuit  to slow it down   but im not sure yet ill have to build it ...
and it seams to me i get better results  with 5 seprate electromagnets in 1 wire   than 4
so i dont know for sure ..
wound another small one in 2 dirrections for 2 way pulseing ...
i will wind my next unit all same dirrection rotated by 3rd's
but i need to find somemore toroides from my big boxes  of  coils   ;D
ist here is a pic
so if i took a small ac joule theif and connected  the ac out of it to the coil pnp and npn  the second coil would pulaste at the rate of the first ..  right but in 2 jt's on the mixer ring .. then i could split that for 6 ou puts ...
so like a nano mk2 could power and pulse this coil .. 12 12 12 12   no ..
plus my output should dubble on my pick up and feed back coils ..  right ...
fishing trip comeing ...   :D
jeanna
Quote from: jadaro2600 on July 14, 2009, 12:47:30 AM
Has anyone tried a low frequency crystal oscillator on this circuit? ..and how would it's circuit diagram look?
I've thought about a crystal cored design, i'm just at a lack as how to use the crystal oscillator part; any suggestions?
I believe they are expensive.
The affordable ones are in the MHz ranges because they are exreas from radio supplies.
They are basically rlc's however.
Take a look at this page (remember to return someday soon, however.  ;) )
http://www.coilgun.info/mark2/rlcsim.htm
I keep this page bookmarked.
It is a java script of a rlc circuit with sliders so you can make some adjustments and get the components or whatever right. - It is very engaging as well as informative.
Down the page is a circuit diagram. The whole site is about RLC as this is Barry's interest.
jeanna
jeanna
Quote from: electricme on July 14, 2009, 08:14:02 AM
@jeanna,
What in the world is gutta,  ...
...:D
jim
Hi Jim,
I'm glad they let you out again!
gutta is natural rubber.
It is white and springy.
RS has this wire they call wrapping wire which is 30 gauge and looks like Al. It is very easy to break.
Its covering which they call kynar is white and springy and and harder to cut than the wire so it is tricky, but it is really good wrapping wire. (It is why I think maybe kynar is gutta)
I think this is what xee2 likes to use, too.
@ist,
I will add your 4 x 4 to my list. It will be easy to do along with the improved TRM primary I will be building today.
(hmm, I gotta get to the HHO because it is summer and i can try things outside.)
@Stprue,
take a look at the last one or 2 posts I made next door.
I found that the addition of another inductor within each circuit off each leg would up the voltage.
So, you should be able to increase each of those outputs to whatever you want with the addition of the right inductor. As long as it is still pulsing, it should continue to work.
Finding the right inductor might be interesting. (And the reason I haven't posted there in a while.)
jeanna
innovation_station
ok that little 4x4 coil just blew my mind ... lol
i just recharged a solar nicad in like 2 min or les .. useing no diodes an led on the coil ...
i may have to built it right up as a simple nicad charger high speed...
now it does drain out ..  slowly but i bet it works as a translateing device
;D
got the little 4x4 singing ..  doing this spikes are not as big but darn it recharges fast ...
ist!
i found another 1 "  so i will make the 2 x 4  x 2 x 4 split like the tesla pattend
ill wind 2 turn  jump 2 turn jump  4 times then i will go in between  those windings in an oppisite dirrection  with the same winding and same wire lengths ...  then in between all the coils ill mk2 winding it ..  because to me this is where that winding gets used properly .. to grab from both ways but 8 of them on a 1 " pulsed  1 2 1 2
it is easyer for me to wind it than to draw it .. it will take much less time to build then draw.....
so i build and take a picture ..
i did only 1 turn jump ..
but here is the coil
ill add the mk2 wires next all 8 of them  ill just put what fits .. all i can do on one layer
PARAV
Crystal Oscillator Circuits
Hi Guys and gals
Check this out for various Crystal Oscillator Circuits.
http://www.discovercircuits.com/O/o-crystal.htm
PR
