Joule Thief
0 Members and 89 Guests are viewing this topic.
nievesoliveras
@all
I already started to explain how I did the self running pulse motor.
My last post is here:
http://www.overunity.com/index.php?topic=6362.msg192400#new
Jesus
innovation_station
how is the external magnetic feild created from the coil mk1 ?
week ? strong ? ..  rotating ...  ? eather spinner ?  lol
if you can get it spinning try some inductors or relay coils ... to grab a bit ....  i dont think you want to tap the coil .. it is like your motor i bet a cupple CONE COILS MIGHT TAP IT WELL ..
never wound 1 yet i do have all the materials for months ... tho
ist!   some day ..
btw i just mesured the led im burning off the cell fone battery .. it is useing 3.7v at 32 mili amp ...
and my battery voltage is not dropping .. it moves up and back down ... lowest it has gone down was to 3.726 highest it has gone up to was 3.733  wile supplying 3.7v at 32 mili amp draw ...
looks like my coil is keeping the battery topped up  i never did mesure the used amount of power ..
it make this irrating sound tho ....   im sure i would get better results with a high freq diode bridge in place of the db107
now that i have this setup what if i replaced my led that is drawing ... 32 mili amp at 3.7v with a second phase step up jt ...  ;D ;)
hummmmm
ill tidy up this set up and take a picture as i see this to be IMPORTANT .....  ;D
after bout an hour to 1.5 hours the sqeeling stopped ... on my coil the cell fone battery voltage had droped and not recovered down to 3.723 and holding ... so im guessing i sucked some juice from my aa  yes it uses some power as nothing is free ... but the returned engery has burnt a led as normal  and a aa alone can not do and it does not drop fast ...  and with out the charger running .. the battery voltage drops 1000 times faster ... lol  i can watch it drop on the meter
nievesoliveras
@all
I did not posted the how to build the circuit for a self running pulse motor photos here because it is not a joule thief.
I will thank anyone that has helped me with the knowledge to attain my goal.
I have accomplished my goal. My pulse motor is self running with a battery from 1.5v to 9v.
Details here:
http://www.overunity.com/index.php?topic=6362.msg192429#msg192429
Jesus
resonanceman
Quote from: Mk1 on July 20, 2009, 02:03:24 AM
@all
I tried the rodin coil jt , i had to do it twice to get it , now first observation i connect a diode bride between the E and C to see the voltage with a old battery a got around 25 volt , now i tried a 3v battery , the meter went crazy , showing -180v on the 200 division and -1800v on the 1000 volts range , but its not right it looked like the meter was going nuts flashing .
I include the drawing i used for making it , i found it easier to concentrate on the wiring angle to find it proper location. This a basically 12 turn bi-fillar.
Did  anyone else notice how similar this  coil is to the one  IST posted  on reply  8363?
The  biggest  difference is the Rodin coil  is  untwisted ....... IST  used a twisted pair.
The  number  of  wraps is  different too ........the Rodin  is 4 laps  of 3 wraps each lap.
IST used  3 laps of 5 wraps  each .
How  much  different is the Rodin  coil  from a standard  coil?
Can anyone verify that the  field  in it rotates ?
gary
innovation_station
here is a picture of the setup i have been on about ...
ist
so it apears i have drained too much engery from my aa battery for it to top it  back up this time ... i bet i need a 3.6v on the input ... with a voltage devider to drop it to 1.5 or 1.2 v constant and then recharge it ..  ;D ;)
it is still rechargeing but at a really slow rate ... so there is a working voltage level we dont want it to drop below ..
