Joule Thief
0 Members and 115 Guests are viewing this topic.
jeanna
Quote from: xee2 on July 29, 2009, 03:08:11 AM
@ jeanna
Why not start with this circuit and get it working. When it is working replace the toroid transformer with the ignition coil.
I have tested this circuit and it works. I have not substituted ignition coil.
What is 4/60?
Is it a toroid?- your big one?  is it a cylinder?
My question about the ignition coil was about how IT is wound and why it would be wound like that. I like using something more tame, so thanks for the suggestion.
thank you,
jeanna
edit,
We posted at the same time. I see the answers.
You seem to have placed this additional toroid in between the existing one and the pos battery. So, it is directly effecting the transistor this way. I doubt a transistor could stand this with a real ig coil?
xee2
@ jeanna
Quote from: jeanna on July 29, 2009, 03:55:07 PM
I do not think there is any problem with the transistor, but that is what experiments are for. Here is another example I did with the simulated ignition coil.
altrez
Quote from: xee2 on July 29, 2009, 04:04:24 PM
@ jeanna
I still have no clue why the other transformer is in there? It makes no sense to me on how to even hook it up? What is the 10/10 for anyway? The Ignition Coil is a transformer it has a + and a - and a HV output.
-Altrez
xee2
Quote from: altrez on July 29, 2009, 04:25:03 PM
-Altrez
The ignition coil needs pulsed current into it to work. The JT pulses the current for the ignition coil.
altrez
Quote from: xee2 on July 29, 2009, 04:29:07 PM
Yes that is true but how do you hook it up? What wire from the JT do you connect to the + on the IC and what wire do you connect to the - On the ignition coil? And why do you need the Toroid? Cant you just use the 2n3055?
I am really lost on the wiring? Do you splice wires from the connections on the 2n3055?
Thanks!
-Altrez
