Joule Thief
0 Members and 120 Guests are viewing this topic.
tagor
Quote from: maw2432 on July 31, 2009, 02:48:05 PM
The quote from Dr. Schwartz refers to this guy Lawrence Rayburn  which I could only find a small amount of info on at this link.  (just a contributor to the circut) (edit)
here is reference :
http://www.overunity.com/index.php?topic=4570.msg150838#msg150838
and Lawrence Rayburn forum is here
--- In OneSmallStepForMan@yahoogroups.com, "Lawrence Rayburn"
http://tech.groups.yahoo.com/group/OneSmallStepForMan/
to get all information on his TREC
=> Subscribe: OneSmallStepForMan-subscribe@yahoogroups.com
electricme
@Ressonanceman,
Quote from: resonanceman on July 31, 2009, 06:38:42 PM
Jim
Great  work on your EEG
If  I understand  right  ....... insulating  the  outside of the pipes makes it possable  to   place them close together .  .... Is that right ?
Is  there any   indication  that  you are getting more than  galvanic  effect ?
I  was thinking that    if   it is  just galvanic  and   the outsides  are insulated .......I can''t think  of any reason they would  have to  be   out in the  yard .
A  big  plastic   box in the basement should  work  just as good  .
gary
Hello Gary, I think as you said, the insulation is the key to its secret why it works, I can see no other obvious reason, none whatsoever, this is my second success with a series earth cell setup, the other one I made just two days before, and it had an aluminium tube with a inner copper pipe.
Positave was the center electrode.
But, the positive is the outer electrode, if the outer pipe is copper.
So copper seems to hogg to the positave side of things, lol
When I saw the combination of volts, then I knew I was on a winner.
When I made the small video showing the voltage riseing, just as you see it, this was the very first time I actually saw this myself too, soo you have all been able to view my success as I had this success.
You could be right there, but I don't have a cellar, so I carn't check this out, one of the chapps replicating this might have one and be able to do this and throw some light on it.
Thanks Gary for the kind words.
jim
electricme
@ Maw2432
I can see you are pritty keen, lol, OK well I had to think of a way to end the tape at the bottom of the tube, I don't like fiddling around too much, its a pain, so the easiest way was to just tear off the insulation tape and tuck it under the pipe.
If you seal up the pipe, when the water/ rain dropps in, if the bottom is sealed, then you will just have sloppy mud. Well try it if you want to, I really don't know what will happen.
jim
I want to make a suggestion to anyone who wants to ask me a question about this EER battery system,
It's not really a JT topic, so if everyone could ask over on the forum here
http://www.overunity.com/index.php?topic=7769.270
it would make the JT topic flow more smoother, although I don't mind answering the questions, I just don't want to distrupt the JT topic.
To the JT members, you have been really patient, thank you all.
Quote from: maw2432 on July 31, 2009, 10:26:34 PM
Jim,  thank you for your detailed reply.
I found some 3 inch zinc machine screws with nuts included for under 2 dollars.    I think the zinc screws will be easer to attach wires to (without clips) using the nuts.  Plus there should be a greater surface area with the screw vs. a nail.   I hope this makes a positive difference.  My copper pipes are 6 inches long.   Cool thing is that I do not have to now remove the darn sticker lables since I need to insulate the outside.  Please tell me about the bottom of the pipe... do you insulate it totally by covering the bottom?
I hope to do testing tomorrow.
Thanks Bill, I'm sure you will be just as surprised as I was.
jim
innovation_station
since were off topic .. lol
ill drop this here too
i did this last winter ...  ;D
im going through my videos ...  i will make some videos of proof ok
lol
even the fet lighting a light bulb
the fact is i can tune to any coil really the coil is only part of it ...  but a properly built one will yeild huge results ...
this is a basic neo zap lighting a 60 watt light bulb  no caps no diodes nuttin
lol
william
http://www.youtube.com/watch?v=Ri_HbDCwf_E
oooo yea YOUR RIGHT AT HOME WHO WANTS CANDY.... LOL
BTW I STILL SEE A HUGE BALL OF ELECTRICTY ...  I COULD TAP AND WHO KNOWS HOW MANY BULBS I CAN LIGHT FROM THIS SET UP I ONLY EVER TESTED THE ONE ... AT 1 TIME ..  I KNOW I CAN LIGHT MANY MORE AND GRAB A FEED BACK AND MAKE IT SELF RUN ...  BUT Y?
THE REST OF THE WORLD MUST DO SOMETHING ...
;D
jeanna
Ist,
Please explain what a neo zap is?
You have mentioned this before, but other than something that involves a permanent magnet, maybe even one wound with a coil, I have no idea what a neo zap could be.
Worse,
I have no idea where to find information on a neo zap.
If it is off the joule thief subject please direct me to the thread where I can find out what this is that you imply can light many filament bulbs.
thank you,
jeanna
