Joule Thief
jeanna
Quote from: nievesoliveras on August 05, 2009, 12:19:08 AM
Nice video! For me an oscilloscope screen is like kapanadze's writing, I dont know what it means.
Thanks.
It is this.
The time goes from left to right.
So, if you look at the line from left going right you can see the voltage goes up and down.
And in the earth it seems that it goes up and down really fast. Not very high or very low, but very fast.
I believe this is what both Stubblefield and Tesla were working with.
They approached it differently, except they both worked with fast oscillating changing charges.
Maybe I need to wind the coil for a crystal battery. There is one wound on a 4 inch diameter oatmeal tube. That would boost the amps, I believe. I am not sure, but no one seems to be able to help much in these areas.
The radio guys all know about excluding waves of certain frequencies, so that is a start. It would be the opposite goal, I assume.
What a lot to study. hmm
I dont know if the transistor is switching off. ...
I will add more wire to the base and see.
I hope it helps.
I have never understood all the stuff people told you that was supposed to help.
jeanna
nievesoliveras
Quote from: jeanna on August 05, 2009, 12:37:24 AM
Thanks.
It is this.
What a lot to study. hmmI hope it helps.
jeanna
I dont know much but there is some information about the wire width related with the amperage and the voltage. I think that it was that if you want more voltage you use thin wire and if you want more amperage you use thick wire.
Also something about lowering the voltage to increase the amperage.
When I worked as a car electromechanic years ago I saw several times that when the battery was low and you tried to start the car the amperage meter climbed to its maximum of 50 amps and if the battery was okay the amperage was about 10 to 15 amps with maybe a little spike of high amperage.
So the low voltage brings the high amperage.
I can be wrong though.
Jesus
innovation_station
Quote from: MrMag on August 05, 2009, 12:23:03 AM
@IST
If the neos are attached to the back of the clip, what are they actually doing? Have you tried the same experiment without the neos?
Yes, you do not use any semi conductors in the circuit but if you ever find a way to harness anything out of the circuit you will need some electronics.
I am also not completely positive but this sure looks a lot like a mini arc welder circuit.
I CAN TAKE POWER AWAY WITH OUT ANY DIODES ...
IT CAN GET PAINFUL IF YOU RECTIFY IT ... I WAS THINKING .. OF USEING 4 FEEDS
THE TRANSFORMER DOES NOT MATTER ..  THE COIL DOES NOT MATTER ...
USE LOW TURN AND THICK WIRE AND LOW INDUCTANCE ...   HERE IS A PIC OF MY LAST COIL I USED THIS WITH ...
YES THE NEOS DO IMPROVE THIS EFFECT I GOT  SIMILAR EFFECTS WITH OUT THE NEOS .. BUT NOT AS NICE ..
IST
I HAVE BEEN DOING IT THIS WAY SINCE I STARTED ...  WAY BACK AT THE TURBO COIL ...   ;D ;)
sparks
Quote from: jeanna on August 03, 2009, 11:30:00 PM
...The earth currents seem to oscillate at a rate of about 2.25 to 2.50Mhz.... end quote
         Current oscillations is what Tesla was talking about.  He called them non-hertzian waves.  These are not your regular emwaves.  Tesla was convinced that radiomen of the day were not taking into account the scalar or compressive electrical waves that can travel through a conducting medium like the Earth.  Imagine the Earth as a dense cloud of charge carriers and you light off an electrical firecracker in this cloud.  The waves radiate just like sound waves through the cloud but real fast.  Like when you hit a block of metal with a hammer how much time does it take the energy to reach the other side of the block.  Now if you hit a block of air not very much energy transfer here.  Superconductors work because they increase the density of the copper atomic lattice (and conductor electron cloud) and the voltage goes scalar.  Plasma is superconductive because the electrons are completley free of the neucleus and coherent layers or tube within tubes of charge carriers can form.  This allows scalar transmission of electrical potential at very high efficiency.  The current flow at velocities of the speed of light not the millimeter or so per second in a normal room temperature negative plasma we call copper wire.
      Jeanna check out those current oscillations to make sure they are coming from the Earth and not an fm transmitter leaking into your detectors.  Great discovery if they are the real deal.  Great work here in the JT thread by all.  Wish I had a lab and some time to help out.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
the_big_m_in_ok
innovation_station said:
THE METAL ALIGATOR CLIPS ...
hey
i took out an inductor from a microwave thick wire looks like 14 turns...  on a small feroite ...
i hooked it up get good results with it too ...
so good i almost blow 800v 3 amp diodes...
Were the diodes in series?  That would be 2400 V. And they got hot?!  Wow.  That might by a good JT circuit.
SECOND ....  LOL  GUESS...  SHE SURE CAN DRAW...  ;D 8)
Is that big picture of you on Reply #8930?   ;) ;) :) :)
--Lee
