Joule Thief
0 Members and 159 Guests are viewing this topic.
timmy1729
@Bill
Where in the circuit do I connect the pot? I've got an unused one from 10 years ago when I made a guitar. Hey!!!  :o :o :o :o   Speaking of guitar... ...
Could there be a use for a guitar pickup? It is simply 6 pole magnets wrapped with VERY tiny wire thousands of times. I've got a spare bass pickup and maybe spare guitar pickup that I could try!
jeanna
@xee2,
I saw your suggestion.
Here is what I am reading off my dmm:
battery itself 1.25VC, also  2VAC
across unlit led 1.25VDC IN EITHER DIRECTION, also 2VAC
On 1 of the leds: 1.2VAC, also  0 .003Vdc
On the other: 1VAC, also 0.001Vdc
Wow, that is interesting.
cool!
Thank you
jeanna
Mk1
@timmy
So far i have not found any use for guitar pickups in this project.You are very welcome to try, I play and build guitar as well.
If anyone wishes to hear me (this is my blues project) http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=300671855
timmy1729
Quote from: Mk1 on January 06, 2009, 04:14:21 PM
@timmy
Is there any particular reason for not using them?
jeanna
Quote from: Mk1 on January 06, 2009, 03:46:30 PM
@jeanna
I don't see the diodes, remember that by connecting leds directly to pickup coil is working but a no no because when the current goes to led it is coming out at the other end and you send it back in the coil,reversing the ripples in the bucket killing efficiency .
I am waayy behind you on this.
When The basic light went out but the 2-y/pick up light went on, I had to check out all these things I did up to now.
however,
I am unsure about the bridge rectifier. Each 2-y pick-up only gives me 2 wires.
Since the 2-y(that means secondary) Is not connected to anything else in this circuit, I need some directions.
Maybe there is a post I missed. I will try to see.
thanks mk1 - this is really terrific, and I appreciate all your help. BTW I am glad you said french. That will help me to understand what you write.
Jeanna
