Joule Thief
0 Members and 101 Guests are viewing this topic.
resonanceman
Quote from: innovation_station on September 02, 2009, 04:11:13 AM
this is the style antenna i have installed in the past ...
for 2.6 ghz
for 900 mhz you want a yaggi ...
http://fskbt.manufacturer.globalsources.com/si/6008800551593/pdtl/Parabolic-antenna/1008182945/2.6GHz-Square-Grid-Parabolic-Antenna.htm
ist
Thanks for the  link  IST
If you  have a few more minutes  I have a few questions  about  antennas like this .
The  one in your link  says it has  a female  N connector     does this  plug right into  a router like a Linksys ?
I  did  a search  on  ebay .     The   WiFi  parabolic  antennas there all seem  to be 2.4 GHz         your link is  2.6GHz      is there a reason for the  difference ?
Thanks for the help
gary
Edit
It looks like the  linksys  has  a small   power adapter
I am  guessing it probably does not  use much power .
With  a JT  charger on a  battery this  whole thing could  be  put up  on a pole  or in a tree
jeanna
Gary said:
QuoteThe   WiFi  parabolic  antennas there all seem  to be 2.4 GHz         your link is  2.6GHz      is there a reason for the  difference ?
Wow!
I will stop trying to do anything with the 2.4-2.6MHz I am picking up with my Stubblefiels coils. I was about to concentrate on the 22Khz anyway, but now, I wonder if the 22Khz is from those antennas . I betcha the wifi is what I have been picking up.
Thanks, now I can go back to real work on my joule thief and let it rain!
thank you IST for providing this info too,
jeanna
resonanceman
Quote from: innovation_station on September 02, 2009, 01:39:45 PM
no prob .. bill
gary ...
its really easy ...
i used an omni ant .. as my access point .. you can put a 1 watt rf amp on it ...
then you can use any 2.6 ghz wireless bridge off the system ... we were able to pull 2+ mbps  no problem  over a good distance
only amping the access point ....  ;)
the bridges we used were 500 ma units ... half watt  transmitter / reciever .. that with a db 36 on the roof you cant go wrong as long as your access point is high enough  like a 70" tower on a hill would do well ...  ;)
ist ...
split this up by 20 people ..  and costs go down fast ...
IST
I found  this  on ebay
http://cgi.ebay.com/Wifi-802-11-g-Router-And-Strong-Yagi-N-Type-Antenna_W0QQitemZ400070135320QQcmdZViewItemQQptZCOMP_EN_Routers?hash=item5d2609ce18&_trksid=p3286.c0.m14
It sounds like it  does everything  you talked about .....except  using  amps .
Does it look  to you like it will do what they say it  will do ?
gary
resonanceman
Quote from: jeanna on September 02, 2009, 05:32:04 PM
Gary said:Wow!
jeanna
Geanna
These  signals  are Gigahertz
I guess you  could be picking  up  a lower harmonic  of them  .
If that is  what is happening     your  equipment   is probably not  fast enough to see the  true  frequency
gary
jeanna
Quote from: resonanceman on September 02, 2009, 06:52:58 PM
Oh, so they are!
Well, now I don't have a reasonable excuse to stop anymore!
So then, I will keep on going !  ;D
I like the spike nature of them even though they are not very big. I keep trying to use the spikes. In a JT the spikes from the basic jt toroid are not hundreds but because they are in a toroid (I assume that is the reason) the multiplication of volts is very high. Yet, I am not getting more than 100mv from it.
Of course that is 10 times without any inductors if you count the stubs as inductors....so I should be incouraged not discouraged.
I want more!!
What I really want to do is make a toroid that is the inductor like the stubblefield. I just haven't figured how I want to stick it into the ground.
Gary,
Thanks for noticing and mentioning my mistake.
jeanna
