Joule Thief
0 Members and 100 Guests are viewing this topic.
Mk1
@gary
I made one with a piece of copper tubing , the piece you can see on one of last page photos.
jeanna
Quote from: resonanceman on September 04, 2009, 01:34:54 PM
Jeanna
You  seem to be describing  a  hard way to make a LM coil
A one inch  toroid like the  5 for $1 toroids fit  perfectly inside the   center of a radio shack wire spool ....in fact  2  of the   5 for $1 toroids will  fit .
I think I always liked your LM  for that reason.
I do not like any of my medium 5/1 toroids.
I always end up with a really weak secondary when I use it.
I did follow that suggestion you made with the red spool, but it was really only successful when I used it on a NS coil. So the interior was cylindrical bifilar.
It worked pretty well.
But even though I wanted to see the outside, what I really want to see is on the inside of the toroid core.
I think there is some action in there that is perpendicular to the ring of the toroid.
I am going to see if I can make this with 2 toroids upside down to each other with a straw wrapped with a coil.
The thing here is if the mag field IS spiralling up through the center of the toroid, I will not be catching it this way. I would need something that crosses the lines...
So, perhaps a larger ring around the outside perpendicular to the stacked rings, so it is in a way that crosses the field.
Maybe I can get the spool to do that for me.
But here is where we need to make our own.
I can use some wire to make a ring the right size... and I will be watching your results too.
Someone a long time ago... was it IST? did this. theNOP said he was using florist wire but I do not remember any reports from him.
QuoteIf  you  put  your primary  next to the   core   I believe you can get by with  5 or 6 wraps   .......it takes more like 20  wraps  if  you  put your  primary on the outside .
Oh hmm. That is interesting.
And, yes it does go along with what I was thinking.
Thank you,
@Stprue, Thanks for the pix. I will study them.
@MK1 Wow, I love the quad!
Please report when you get any (even disappointing) results.
That has great promise.
jeanna
stprue
@All
I posted this on the sm topic but though it would be good here as well.
What do you think of this little test!!!  It is kinda like a small tesla hairpin circuit.  The interesting thing about it is that it is lighting an led on a different JT circuit...no contact.  Also you can see voltage reading off my DMM that's connected to my JT!  What are your thoughts on this?
kamax
Hi,
The setup of stprue give me some idea and have played with my joule thief. i don't know what i have really done but it looks like i have decrease the milliamp of my joule thief.
Without any load on my transistor i read ~50ma(is this normal?), with a led it's only ~1ma more.
I have make a coil with a crystal core and have connected it to the two wires going out of my normal toroide. For the input of the crystal core coil i have make it like a joule thief toroide, one wire from opposite side.
I can put leds in the two directions on the output, they will light but are stronger in one side. Looks like i have AC. The stange thing is that if i put a led in the strongest side, i read less milliamp going out from my battery. More leds i connect less mA i read but it don't get to 0mA. When i reach ~36mA and connect more leds, it get more mA.
It works with a toroide too instead of the crystal core coil but instead of taking a wire from different side for the input, i must take the two wire from the same side.Very strange.
Here is a video: http://www.youtube.com/watch?v=_O9jrp0tHT4
innovation_station
HOT DOG!~!!
Lol
YOU ALL SEE THIS ...  ;)
THIS IS A TRUNK AMP...
I HEAR YOU CAN TUNE THEM
FOR THE YAGGIES ...  WE ONLY EVER USED THEM ON THE 900 MHZ UNITS ...
BUT THE TRUNK AMPS IM PICKING UP TOMMOROW .. ARE 1 GHZ ...   ;D
SHIT ... I DONT KNOW HOW MANY WATTS ... I BET A FEW THO ..
THIS IS A TRUNK AMP ...
http://www.c-cor.com/broadband_access/files/products/FM901eT-AT-1106B.pdf
AND I DONT THINK THE ONES IM GETTING ARE THE EXACT SAME ... BUT FORSURE 1 GHZ
PROBALLY DROP THE CELL TOWERS IF NOT USED PROPERLY ...
THE THING I DID LEARN WAS THE CABLE MODEMS .. CAN BE USED AS WIRELESS WITH THE CORRECT ANTANNAS AND AMPED OF COURSE ..
IST!
