Joule Thief
0 Members and 55 Guests are viewing this topic.
dllabarre
Quote from: jeanna on September 11, 2009, 10:26:36 PM
Hi DonL
The schematic is the same. Just the toroid changed.
I guess I could make one for the record... oK I will.
jeanna
Thank you for the schematic
What size wire are you using on the Toroid?
each 4 turns:
306 turns:
What is the diameter (outside & inside) of this Toroid?
NICE WORK!
DonL
Mk1
@all
My survival instinct got me searching , this need to be seen by every one .
http://www.youtube.com/watch?v=pyofhLYYVC8
1.5 volt light now heat .
stprue
Very cool Mk1...nice find!
jeanna
Quote from: Pirate88179 on September 12, 2009, 12:23:04 AM
Jeanna:
Nice job!  On the larger tube, try using a neo (a very strong one) to "drag" the light down the tube.  I have done that and it seems to work.  I have no idea why.  Once the entire tube is lit, remove the mag. and it stays lit.
Great going.
Thank you!
I did try that and every other trick.
Today without any plan except to learn the edges of this since it was already successful... I took out some of the caps and tried it without the magnet/s.
I could do almost anything except remove the magnets on the 4w but no thing I did made the bigger one/s light.
Here is how close it is, though:
I put one magnet on the left side and I hold the tube with my left hand.
I snap a magnet onto the right connector and as long as my right hand stays there, the tube just under my hand lights up. I can spread the light to the right about 1/3 the length of the tube then even that stops.
If I put my hands on both ends the light is out.
I took out most of the battery caps and even the 68pF base cap, and the light stayed on.
But I needed the resistor cap to start it.
I am wondering if the AAA is just too wimpy. It only lasts about 30 minutes. Maybe that startup just takes too many amps. It only holds 750mA fully charged. A pair of these work for weeks/months with an ordinary dc circuit with a 47ohm resistor. I think I need to try a AA before I am done experimenting with this one.
@Lee,
I am letting others do that part.
When xee2 reported that he had an easy start on a tube when he put one of his pickup lines back into the battery, I tried it, but it didn't seem to help me too much. The magnet seems to be my best starter switch.
I am watching those people and I take note of what they do.
jeanna
edit
Yes, MK1 those are cool videos.
2nd edit
Quotehank you for the schematic
each 4 turns:
306 turns:
NICE WORK!
DonL
The toroid is about 1 1/4 inches OD and 1 or 7/8 inch ID.
tor-61 from allelectronics.com 2/$1 ooo expensive 50 cents!  ;D
It seems to be the same material as the tor-23 which I love. I got my wish. I wanted something like the tor-23 that was big enough to hold more wire.
I used 27awg wire. It is red cuz I got it from gobrushless.
The 4T,4T are made of telephone wire.
I made progress in the method of winding the toroid or rather managing the 24 feet of wire.
I loaded a bamboo barbeque skewer into the end of my hand drill. Then holding the counted out 24 feet of wire in one hand allowed it to feed onto the skewer as I turned the drill's handle. It went on easily and allowed me to 'sew' the  wire through the center. I had to tug at the end, but there is still a lot more room for more turns fed through without the skewer.
j
dllabarre
@Jeanna
Thank you for the details on the toroid!
DonL
