Joule Thief
0 Members and 98 Guests are viewing this topic.
Pirate88179
@ Gary:
I understand what you are saying about when the battery state changes, it alters the circuit and it moves out of resonance.  This make sense.  However, what if you charged to a supercap, a large one, do you think the charge state of the supercap would alter the resonance the same as the battery?  Or at all?  If it doesn't, or if the effects of charge state is much less using the supercap, you could charge the large cap, or caps, and then periodically dump the full supercap into a battery which would otherwise be isolated from the circuit.  This could be done fairly easily in an automatic manner but, I would not waste time on designing that unless/until you find that the supercaps keep the resonance of your circuit in tune despite the charge state.
Just a thought as I was thinking along these line with my Bedini experiments.  I have not pursued this at all yet.
What do you think?
resonanceman
Quote from: Pirate88179 on October 14, 2009, 07:26:09 PM
@ Gary:
What do you think?
I  have not  done much  with caps ....  I have tried to  use a cap  a few times  to see  if  I could  remove the  battery once I  got to the self charging state .
IN each attempt  the  circuit  went  off pretty quick .
I think  that the chemical  reaction within a battery   acts  as a buffer .
With  a cap .....no matter how  big it is .......if you take  a pulse out .....your next pulse is  going to be smaller .
I  have been thinking  of ways  around  the  resonance thing .
One thing  I have been thinking of it having  several levels .
Normal   running  might  be   at a certain  voltage ..........but if you  draw more  power .....the  voltage  drops down into the  resonance  range of another  JT ......or 2
The only  way  that I can think of to  build  this kind of  layered  system is to  use a very accurate power  supply  that can  deliver   a specific current at  different  voltages .
I  guess  I should  look into  making  a  wall   powered  self charging  JT ....... if it stays in resonance   it  will  validate   a few  of my  theory's
gary
jeanna
@gary,
Wouldn't your system stay reasonably tuned if you had a few batteries in parallel?
I have a few hours to play with any circuits when I use a AAA, but when I change them to AA with 4x the mAH's, the circuit changes very little for days.
In fact it is a part of my thoughts for future strategy.
A pair of D cells or a bunch of AA in parallel would light up my fluoro from the camera circuit for 4-8 hours without further modifications.
Can't this work for all of us in some way?
jeanna
resonanceman
Quote from: resonanceman on October 14, 2009, 08:12:41 PM
gary
I had an idea that might  make  caps  or even batterys  more buffered .
It involves    connecting  the   cap or battery  directly to   a large  depletion-type MOSFET.
The  gate of this  MOSFET  would have   a cap  connected to it .
The  gate cap  would  be  connected  to a diode   or bridge .
The  diode  would  be connected to an extra winding on the   toroid .
This  extra  winding on the  toroid  should not  take much  power to run .
It  is not  exactly  the  JT circuit ..........but  it  will represent what  is going on with the JT.
It  should  only provide enough power to get  the  cap  charged   to the working  voltage of the  MOSFET .
If you  want more buffering ........ add more capacitance to the gate .
In short .......as the   JT  works harder .......   more  power is induced in the extra winding ......the gate cap charges to a higher  voltage ......and  causes  the MOSFET to  increase in resistance .
When the  JT is  working  less  hard  the gate voltage will drop  and  cause the  MOSFET to decrease   in resistance
resonanceman
Quote from: jeanna on October 14, 2009, 08:34:25 PM
jeanna
Jeanna
I agree ...... larger  batterys  should  greatly help the problem .
That is  part of the reason I  have been working on  a 12 V system .
Another  reason is  with the right  cores .......12V  should  provide much more power .
I have not  had much time for expermenting lately ......
I did  get  a couple  TIP3055s  and   I am looking forward to seeing  how long it takes to fry them .
gary
