Joule Thief
0 Members and 133 Guests are viewing this topic.
the_big_m_in_ok
Quote from: jeanna said:
@Lee,
url=http://www.overunity.com/index.php?topic=6942.0]http://www.overunity.com/index.php?topic=6942.0
It is on the page where all the joule thief type threads are.
Thanks, jeanna.
I'll look at the whole thread a little at a time and download printoffs of some schematics now.
I'll have more chances to experiment in the future, as the economy will force changes on me that I'll have to accept like a lot of people.
Thanks again,
--Lee
innovation_station
HERE IS A PICTURE OF THE RING CORE IM USEING AND THE ENCLOSURE FOR THE OU RING ..
THIS IS TO ENSURE ANY RADIATING RF IS COUGHT IN THE ALUM CASE AND SENT TO WORK ...  ;)
SHOULD THERE BE ANY....  THIS CASE IS HEAVY LIKE 20LBS OR MORE ..  ITS LIKE IT WAS BUILT FOR MY RINGS....  I WILL MOUNT 2 IN THIS CASES LID ... YOU CAN SEE WHERE THEY GO ...
OTHER PART WILL HOLD THE DRIVEING UNIT AND RECTIFER BOARDS ... SO YOU CAN SEE WHY I CHOOSE THE DB 107'S..... LOL   JUST MAKE BOARDS OF THEM ...  ;) THE ENTIRE THING BOLTS TOGATHER AND IS WEATHER PROOF!!
THIS IS THE HEART OF THE !CUBE PORTABLE POWER SYSTEM!  THE CASE WILL BE MOUNTED INSIDE A BOX AS WELL THE CAP BANK AND INVERTOR AND THE POWER CORD TO CLOSE THE LOOP
IST
HOPE THIS ANSWERS SOME QUESTIONS ...
MY COSMIC ROSE JT KINDA LIGHTS UP AS AN OUTPUT WINDING CONFIG ....
LOL
HOW MANY OF THOSE AROUND JUST 1 LAYER?  YIKES  WHAT IS SHOWEN IN MY PIC CAN BE USED AS A SYNCED DRIVEING SYSTEM TO INCREACE AMPRAGE INPUT TO THE DEVICE AS WELL THEY COULD FIRE IN SECCUSSION RAPPIDLY...  ;D ;)
THAT BEING SAID .......   LOL
THIS DEVICE CAN HAVE 2 MODES OF OPERATION ....  CHUGGGGGG ALONG MODE ... TO JUST KEEP THE BANK TOPPED UP ...  OR LOAD MODE ...  WHERE IT IS COLIDEING THE FEILDS OF EACH COIL
THERE IS NO LIMIT ...  THIS IS WHAT MAKES THIS SUCH A HARD THING TO GRASP ...
IST     GET LIT!
THE 200 2N2222A NPN TRANSISTORS I OREDED CAN HANDLE LIKE 75VDC AT .6 AMP EACH  HUMMMMM
http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&freeText=2N2222A&search_type=jamecoall
I ORDERED 500 BRIDGES ...  THOSE CAPS ARE GONNA CHARGE ...! LOL
gadgetmall
Quote from: jeanna on November 09, 2009, 07:53:15 PM
Nice Albert,
I am glad you can share a pic or 3 today!
I assume that with so very little ampsdraw that this is running off the secondary.
The cap is ? at the resistor?
Is that 250,000ohm? or is the color off on my screen?
Or is it something else... not a resistor?
It sure is bright.
Ain't it nice to be able to makes the room bright with an older battery?
thank you,
jeanna
(Hi ist are you going to give any details on which of all the circuits you are using all those caps on?)
@Lee,
Hi . I am running the half watt tophat on the CE of the transistor and the 100 milliwat on a150 turn secondary rectified from a supercap . the black cap on the little piece of circuit board  . no batts in this one at all  . Actually i think the resistor is one i had and the pot is 5k . This one needed a lot of resistance and caps for a tank to get it to oscillate at low est volts . The Germanium is not like silicon . it needs lots of wire and lots of resistance . Once that is done amazing things can be done like light half watt even three or 4 with juts a touch up on the pot . I have another one running 7  half watter . It has a rechargeable c cell in it . The draw is is a bit higher but im not using germanium just a regular 2n2222a . its 5 ma in . Still a little work on it and making it better appearance . then I have another Cube with My E-light circuit in it . still in proto stage but called it the Infinity Cube light . It uses newest Barium/germanium and charges up to 6 volts worth of batteries Plus lights 2 one watt tophats . I'll have more time to reduce the pictures and i see if there worthy . These Plastic Cubes are perfect for Light Projects and CIS solar cells . Love em .  I buy them from a local Sporting good store . there baseball Displays for the trophy case  :) seal up nice and are UV resistant
Albert
innovation_station
AWESOME GADGET!!
YOU SURE LIKE THINGS TO BE CHEEP AND EFFICIENT!  ;D 8)
IN LOOKING AT MY BIG RING ...
I WILL MOST LIKELY HAVE 24 POWERED WINDINGS PER/ TOROIDE BOTH WILL BE HOOKED TOGATHER ..
12 / TOROIDE WILL FIRE IN SYNC ON 2 TOROIDES ...  AND THIS CAN BE TOGGLED BETWEEN LOAD MODE ..  WICH THE OTHER 12 COILS ON 2 TOROIDES WILL FIRE 1234...... REALLY FAST SO THEY OVERLAP ...  ;)   THEN OUTPUT WILL BE WOUND ONTOP ...   AND THE CORE SHOULD BE TUNED AS WELL AS WIRE / HIGHEST V / TURN OF WIRE ..  I WANT ABOUT 14VDC OUTPUT X AS MANY FEEDS AS I CAN GET ..  OR WE MAY WELL FIND HIGH VOLT WORKS BETTER ....
WHO KNOWS AT THIS POINT...
this is another reason for the DB107'S  0-1000V 0-1A
IST!
SMILE !  UNCKLE KRACKER  :D
http://www.youtube.com/watch?v=lB1UJsutvkc
OOOOOO   THIS TOY MAKES ME SMILE....  :) :)
jeanna
Very nice,
thank you ist . This is very heavy duty,
and
thank you Albert. (I like the looks of the cube too. I will check out where I can find a trophy case display cube. I don't think they do sports here but they do fish... maybe they do trophies for big fish.  ;D )
jeanna
